I'm looking to buy a C5 soon and would appreciate some feedback on how realistic my budget is.
Here's my criteria:
- Around 70-100k miles.
- 6 speed
- Coupe style, no FRC
- Great mechanical condition, mostly stock, properly maintained
- Good cosmetic condition. No peeling clear or major damage, but some scratches and blemishes are fine.
- Around 15k budget. Willing to go up to 17-18k for a clean 2001-2004, but would prefer to spend 12-13k on a clean enough 1997-2000 (no ABS/TC doesn't bother me).
- Located in NY, would prefer local but willing to travel for a deal
I'm also planning to do some work on it - HCI, suspension, etc. I know I can find a car cheaper with these mods done, but I want something to wrench on, and enjoy gradually making the car faster.
If you were looking for a driver's quality C5 to do some work on, how much would you spend, and what years/mileage would you go for? Spend more on a clean later model, or less on an earlier model?
I inherited my 2K coupe, price was not an issue....However regular repair and parts replacement can get $$$$. Mine needed tires, shocks, starter, exhaust for starters, that came up to a few grand. Something to keep in mind when figuring your budget.
Great point, I'm pricing in ~3k for parts to get it road worthy, as well as taxes and what not. I usually like to change all the fluids and some basic items like plugs when I get a new car regardless of the condition.
Curious if your exhaust rusted out, or if there were emissions issues?
Thoughts on your question which I include my experience with my '98 base coupe would be lower the miles the less you are going to have to repair for now. You want to have some $ for making it the style you envision after you have owned it for a little while.
If you’re getting a 6sp, take a good look at the clutch master. If it’s really dirty, you may be looking at a slave cylinder and while you’re in there clutch and torque tube freshen up.
If you’re considering an ‘04, ask if the driver side fuel tank has been replaced (yet). Many were fixed under warranty. Very expensive.
If the car has F45 or F55 suspension have it thoroughly inspected.
Good C5 hunting for your avatar. Just get out and look at what is available through dealerships and private owners within your price range and the "must be's' That will give you a clear idea what is available for the $$ you want to spend.
Maybe if you run into a really good deal but I think you’ll need a bit more for a 6speed. The coupe 6 speeds aren’t really that common. As strange as that seems. The good news is you’re not way off and this is the time of year to find a deal. If you had about $3000 more in reserve I think your options would go up.
I don't think 15k is enough. It's possible, if you search nationwide for six months to a year. If you want one within a month or two, fairly local it will take a bit of luck to find it.
There are a few on Autotrader that seem to fit your criteria.
Is this driver side fuel tank issue only a problem specific to the 2004 model year? Can you please explain a bit more? I am looking to buy a C5 as well. Thank you.
C5 is great car.
1. If you can find a Z06 or Hardtop for your price they have more vlue , less built
2. Stay newer than a 2000. 2001/2004 easyer to find a ECBM . Those can be rebuilt the older 2000 and later can not and can cost used $3000.
Good luck in your search
This-6 Speed in Coupes is a bit of a unicorn. Not impossible to find, just not common. I looked at 7 cars including 2 Z's and none of the non Z's were manuals.
Plan on needing tires (check the date codes), flex lines and pads for each corner. I bought an 02 in Jan of this year. While to flex lines could have stayed on, there was some light cracks and I wanted to know my brakes were good so fresh SS lines done. If you are lucky, the car you find will have decent tires to hold ya over since it is winter.
My journey with C5s began in early 2022 when I purchased my first one, a 1999 A4 Coupe boasting 90k miles. At $12,000, it was a good price, but it needed some work—general maintenance, new tires, a harmonic balancer, paint touch-ups, suspension overhauls, and a tune-up.
The second C5 I acquired was a 2003 MN6 Convertible with just 30k miles, a beauty that cost me $21,800. Surprisingly, it demanded a similar level of care and maintenance as the '99, despite having more than half the mileage.
Now onto my third C5, another 2003 model, this time an MN6 Coupe. While it required an EBCM repair, I'm planning to refresh all fluids and replace the wear-and-tear components soon.
In essence, owning these 20+ year old cars has taught me that they all demand a certain level of tender loving care. Maintenance remains key, regardless of the mileage or specific model year, but 2001+ is preferred.
Originally Posted by Vader_C5
Based on what I am seeing listed, those numbers/estimates seem low to me, but what do I know
Add around $10k on each year when you bump up to a #2 excellent condition C5. That's a trophy winning Vette.
I've always thought most nice cars fall somewhere in between...
They are a nation wide average I believe. With the OP being in the NE market I would be they are low as you say. The best deals always seem to be far away when I’m in the market.
