C5 new tires
Old Dec 16, 2023 | 12:19 PM
bookyoh's Avatar
bookyoh
I am on my second set of Michelin run flats over 9 years of ownership. I like the feeling of some level of security that I can drive the car to get a flat tire repair rather than waiting for a tow truck that can transport my car without loading or unloading damage to it.
Old Dec 16, 2023 | 01:03 PM
hyperv6's Avatar
hyperv6
One thing to keep in mind is run flats are heavy, expensive and ride harsh.
If you choose to go with out run flats generally a small compressor for $35 in the trunk 90% of the time will get you where you need to go.
I have added this to all my cars even with spares as the side of the road is not a good place to work with people driving distracted.
With tires today few go flat fast and most get a slow leak. I just top off the air and drive it to a shop or home then remove it for repair.
I also avoid stop leak as it just makes a un necessary mess in most cases.
Flats years ago were a very common thing. But with the advent of the modern tire they generally will not go flat immediately. The item will stick in the tread and leak slowly. Many times people will have an object in the tire and never notice till they rotate tires.
Old Dec 17, 2023 | 01:44 PM
Tron Z's Avatar
Tron Z
Originally Posted by DDaaryl
Tires are dated and degrade over time. Many owners have changed their tires due to age and dry rot rather than mileage and tread wear. I'd wait until spring for a tire purchase if I were you.
^ This
There is also the concern of the tires flat-spotting due to sitting for months at a time, without moving the vehicle. If it were me, I would wait until Spring to replace the tires.
When you replace the tires, that would also be a good time to replace the batteries in the TPMS sensors (if so equipped), if not the sensors themselves. The batteries tend to last for only a few years. Note that there are two types of sensors and they are not interchangeable.
Old Dec 17, 2023 | 03:49 PM
Mitch45's Avatar
Mitch45
several years ago my 98 needed tires . I was not thrilled with the idea of spending 2 , 3 4 hundred per tire . I did a lot of research and ran across Achilles sports . Before they split off on their on , they were partnered with manufactures like Pirelli . I bought 2 from Walmart and 2 from Tires Easy . Had a local tire shop mount and balance total came in at 398$ . Have put around 6000 miles on them . That includes a round trip on vacation of about 1300 miles . Not seeing excessive wear . Actually not seeing much wear at all .
And like the OP my C5 is stock and is a weekend cruiser .
Old Dec 17, 2023 | 07:18 PM
Photomania's Avatar
Photomania
If you are looking for all season capable tires, Michelin Pilot Sport A/S 4 is a great choice. If you just want a good summer tire, check out the Hankook Ventus V12 EVO2.
I have Michelin Pilot Sport A/S on my Stingray and they grip well, especially on a sharp turn on an interstate highway that I often use. I ran Sumitomo tires on my C4 and Continentals on my C6 and C7. All did well.
Old Dec 17, 2023 | 08:50 PM
RedC5's Avatar
RedC5
Just put my new boots on this weekend! Rides like a new car now! 😝
Old Dec 19, 2023 | 02:22 PM
Papip's Avatar
Papip
I also run the Firestone Firehawk Indy tires. I live in North Jersey, don't use the car in the rain or snow and have no complaints at all. They are summer tires, but if you are putting the car away in the winter, I'm sure you would be pleased with them.
Old Dec 19, 2023 | 08:19 PM
Sting99's Avatar
Sting99
I agree best tire I ever had was the Hankook Ventus v12 evo’s ….. I can’t get the size I want on the all square 18 inch , so went with the Continental tires….. but when it was stock the Hankooks from Tire Rack was a great deal
Old Dec 20, 2023 | 08:40 AM
nitromainia's Avatar
nitromainia
And Them... Out of left field
...... Bought a decent 2001 with....
Wait For it...
Sumitomo’s. !!
The Cheapest tires out there!!
Previous owners “Sell the car with new tires choice”
And Made in Original fit 17 and 18’s for stock rims
I’m actually a closet Tire Fanatic, and “somewhat sporty” driver
So I can say
Reasonably decent in the Dry. Fair to good in the wet
Surprisingly decent ride quality
​​​​​​ Once you get over the “Shame and Embarrassment” of
“Not Having What the Cool Kids have” factor
You realize they are An Exceptional Bang for the buck
Round....
Balanced out well
Smooth @ illegal speeds
There you have it
C’mon Down
The Cheap Seats are Just Fine!
USA-1
Save The Wave
Old Dec 21, 2023 | 07:46 PM
davisce's Avatar
davisce
Michelin Pilot Sport A/S Tires Gets My Recommendation.
I’ve run Michelin’s on my 1999 C5 since it was new. The first 10/11 years
I owned my Vette (1999 – 2010) I lived and worked in Germany and with the weather conditions as well as the speeds on the Autobahns (100-150 mph) the Michelin Pilot Sport A/S tires never gave me any cause for concern in either
performance or safety.
Just My 2¢ !
Old Dec 22, 2023 | 08:53 PM
RedC5's Avatar
RedC5
Just My 2¢ !
I just put in the ZP’s last weekend - first time with Michelin - yup - they ROCK!
Old Jan 6, 2024 | 09:23 AM
grampak's Avatar
grampak
4th Gear
Thank You to all who responded to my post. Went with the Michelin run flats, bought them at Discount Tire on a sale and won't pick them up until April. "Smooth" is going to Livernois Motor Sports in February to have the harmonic balancer replaced, tensioner pulleys, serpentine belt, plugs and wires. Any other suggestions as to maintenance? Already have done oil, filter, air filter, MAF cleaning. Having a ball with the car.
Old Jan 6, 2024 | 10:13 AM
  #33
captain vette's Avatar
captain vette
you might want to change coolant and transmission fluid if it’s a manual and also pumpkin fluid
Old Jan 6, 2024 | 02:08 PM
  #34
c5arlen's Avatar
c5arlen
The little bitty patch of tire contact is everything!!.... Like Safety... Ones trust should be questioned when driving ones Corvette with its quality of tires... Do you trust your driving skills? .. Do you trust tires that are not Michelin?.... Eh Big Guy?... Not me.
Old Jan 6, 2024 | 07:21 PM
  #35
Dads2kconvertible's Avatar
Dads2kconvertible
Originally Posted by c5arlen
Do you trust tires that are not Michelin? Not me.
Of course. The vast majority of tires sold around the world are not Michelin. They are probably not even the most common brand sold by @Discount Tire but it wouldn't surprise me if they were the highest total dollar amount sold.
Old Jan 7, 2024 | 06:29 AM
  #36
VetteDrmr's Avatar
VetteDrmr
Brake fluid flush. Especially since you're going to be driving on the street, I use Valvoline synthetic DOT 3/4 and flush it every 3-5 years. If Smooth is a manual, then suck out the tank and replace with fresh as well (darn near impossible to flush the slave cylinder without 2 people and a lift).
BTW, I know you just bought tires, but here's another vote for Sumitomo HTR line of tires. Got almost 300k on our C5, and between her and our other cars, over the years probably have >500k miles on Sumis. No problems on the road.
Welcome to the nuthouse, and have a good one,
Mike
Old Jan 7, 2024 | 07:21 AM
  #37
BRKLYN's Avatar
BRKLYN
Get tires in spring, Me personally have run Kuhmo ECSTA, very pleased with them. Hen in PA I got a set of Hankook Ventus V12, and again very please with them, by the way non run flats. Buy a portable compressor and repair kit, most of the time you can repair without taking wheel off. Stay away from run craps, I like a soft riding tire, the suspension is harsh enough, those run flats are terrible ride and noise. I forgot to mention get a lug power tool if you work in your car, I’m 68 I bought one last year and makes it easier when checking breaks or replacing wheel hubs. I only had three flats maybe four since 2006. Happy tire hunting and drive it everywhere.
To C5 new tires
Old Mar 13, 2024 | 03:41 PM
  #38
grampak's Avatar
grampak
4th Gear
"Smooth" is getting it's "spring cleaning/tune up" as we chat. New Michelin Run flats April 10th. Any suggestions as to which gel cell battery to buy?
Old Mar 13, 2024 | 03:52 PM
  #39
Five O's Avatar
Five O
Hey VJ, I read your post and checked against my car. I have Ventus V12 on it. They have been very good. Replacing tires now but when I checked Discount Tire told me C5 stock size on either front or rear was discontinued so I could not get a matching set. Mounting the Firestone Indy 500 as we speak.
Old Mar 13, 2024 | 03:54 PM
  #40
acroy's Avatar
acroy
Odyssey
Cry once, never regret it.
