MGW Race Knob help!
Old Jan 6, 2024 | 02:40 PM
mcbrucey's Avatar
mcbrucey
Default MGW Race **** help!
Hello,
so I installed the MGW shifter box myself and a couple months later, I purchased the race ****. It arrived today and it has a set screw on it, washers and something to hold the boot up I think?
Does anyone know if this **** will work on the threaded shifter for the C5 or do I now have to order the non threaded piece?
Also, anyone know how the rubber seal works with attaching it to the shift boot?
thanks!
Old Jan 6, 2024 | 02:54 PM
johnnyp420's Avatar
johnnyp420
I'd reach out to MGW directly. Im sure someone knows the answer on the forum, but MGW has pretty decent customer service, so I'd bet you would have an answer in a few minutes with a phone call.
Old Jan 6, 2024 | 06:56 PM
They certainly should know the answer.
Old Jan 6, 2024 | 07:04 PM
mcbrucey's Avatar
mcbrucey
for sure was just hoping someone had experience with it before Monday.
Old Jan 6, 2024 | 09:23 PM
Dads2kconvertible's Avatar
Dads2kconvertible
I don't see "race ****" on their site but of the four ***** this is the only one that doesn't say Mustang. Have you watched the installation video?
https://www.mgwshifters.com/shifters...s/*****/hammer
Old Jan 6, 2024 | 11:47 PM
LowcountryVette's Avatar
LowcountryVette
Yes it will work fine. Spin the **** on to the height you want and tighten set screw to keep it there.
Old Jan 7, 2024 | 02:02 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
If the shift **** is threaded then it ought to be correct for the threaded shaft with the shifter. The little screw mounted to the front of the shifter is to lock it in place on the shaft. On my older one the shift ball has a delrin or similar plastic guard inside and the screw locks that firmly against the thread. In my case I went through the plastic in time and since I had the height I wanted I did not mind putting the set screw firmly into the threading. It has never budged.
Old Jan 7, 2024 | 05:00 PM
mcbrucey's Avatar
mcbrucey
Thanks everyone for the help! I messed around with it today and got the ring installed on the shift boot and then got the shift **** on. Looks great, can’t wait to drive it
Old Jan 9, 2024 | 11:24 PM
johnnyp420's Avatar
johnnyp420
Pics or it didn’t happen!
Old Jan 14, 2024 | 12:38 PM
benflynn's Avatar
benflynn
I use a Hinson ball on my mgw shifter
Old Jan 15, 2024 | 07:12 AM
Jjaooy's Avatar
Jjaooy
Banned Scam/Spammer
Nice, I also used Hinson ball as well
Old Jan 15, 2024 | 04:33 PM
schmuckingham's Avatar
schmuckingham
What he said. Mine is as far down as you can go.
Old Jan 15, 2024 | 04:39 PM
Tusc's Avatar
Tusc
Which one is that?
Old Jan 15, 2024 | 04:57 PM
schmuckingham
Originally Posted by Tusc
Which one is that?
On their website, if you go to the Corvette shifter they list it as an addition item as a "Race ****" .
To MGW Race Knob help!
