[Z06] Paint damage behind front passenger wheel
Old Jan 16, 2024 | 08:29 PM
mindys's Avatar
mindys
Default Paint damage behind front passenger wheel
Hey guys. Got a 2003 torch red C5 Z06 with 72k miles. Noticed this bad paint damage behind the passenger front wheel. Driver side does not look like that. Got this car during the summer. Has this happened to anyone else? Is this proof that the fender was resprayed? All body panels seems to match in terms of color and orange peel. Recommendations to fix it? Thank you.
Old Jan 17, 2024 | 09:26 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Right/passenger side always sees the worst paint damage from rock chips and the like (in the US), as that's where the shoulder is on the roads for us with the most rocks and debris.
I would just touch it up with matching touch-up-paint (plenty of posts here on how to obtain), and then install a set of RPI splash guards to keep everything looking in good order.
https://www.rpidesigns.com/shop/item...RoC-t4QAvD_BwE
Old Jan 17, 2024 | 10:19 AM
hyperv6's Avatar
hyperv6
You likely have sand blasting on the rockers all the way back.
I sprayed mine with spray paint and then took an aggressive polish pad with a orbital polisher and it removed all my blasting.
I went with these flaps. No drill and they use existing bolts. They are adjustable too. Note the car in their add has too large of a tires but these are the best I have found with no perinate holes or scratches. They are in a number of colors too. I did black on torch red as they blend into the tires.
https://rokblokz.com/products/chevro...d48747c6d56d2c
Old Jan 17, 2024 | 04:32 PM
RPIDON's Avatar
RPIDON
Platinum Supporting Vendor
Hi sir .. please use newyear24 discount code in our website
Old Jan 17, 2024 | 05:15 PM
Trickskier's Avatar
Trickskier
I use Dr Color Chip to touch up rock chips. Very pleased with results! Link below:
https://drcolorchip.com/?gad_source=...SAAEgIJx_D_BwE
Old Jan 17, 2024 | 05:24 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's called "road rash"..........
Old Jan 17, 2024 | 05:39 PM
hyperv6's Avatar
hyperv6
Torch Red if not faded is one of the easiest touch up you can do.
‘Auto zine and most parts stores have spray and touch up. Duplicolor natches perfect.
Old Jan 17, 2024 | 07:23 PM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
I purchased these splash guards and they are awesome. They do the job and look great also!!!
Old Jan 17, 2024 | 09:50 PM
mindys's Avatar
mindys
Thanks for the info guys. I was thinking this was normal, just haven’t seen it this bad on other cars, but then again never owned a car that’s 20+ years old.
Gonna touch up and put some rock guards on this spring!
Old Jan 17, 2024 | 09:59 PM
JDiv48's Avatar
JDiv48
I need to do something come spring as the trash on the roads here is terrible.
I hope some of the folks will post some pics of NO drill splash guards on their c5s
Old Jan 18, 2024 | 12:30 AM
Not really all that unusual to have damage there. Tires kicking up rocks chip away at the paint fast. Short of adding some splash guards or PPF, it’s going to happen.
You can get factory matching paint and touch up the area.
To Paint damage behind front passenger wheel
