Plastic Ignition Bezel
Old Jan 25, 2024 | 11:25 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Plastic Ignition Bezel
I recently swapped in a new double din head unit and now notice that the plastic ignition bezel has some movement to it. Even if I don't have the key inserted, I can move it with my finger, etc. I really never paid attention to it until after I installed the new DD unit so I'm wondering if I incorrectly re-installed the bezel. I know if needs to be aligned correctly with the ignition wire/clip, which it is, however I just don't remember it having this much play earlier and wonder if I missed or broke a connection tab.
Appreciate any advice or insight.
Edit: So I found this video on You Tube so apparently there are three tabs that need to be connected. I don't think my two tops taps are which is why there is movement. I'm hoping I can make the connection without having to remove the entire bezel (again).
Old Jan 25, 2024 | 10:22 PM
jdmvette's Avatar
jdmvette
Night Owl for life
here's a new one if you need it
https://www.ebay.com/itm/40469180531...Bk9SR6SOyryoYw
Old Jan 26, 2024 | 12:52 PM
MSG C5's Avatar
MSG C5
Originally Posted by jdmvette
Thanks. I just tried messing around with it and can't get it to stick to the tabs and still moves around. I guess i will need to remove the radio center console to see if any of the tabs are broken. If so, I will need to order a new ignition bezel.
Old Jan 27, 2024 | 07:54 AM
Good luck - hope you can get it to stay in place without a new part, but thankfully the C5 console is not too difficult to remove and put back together.
To Plastic Ignition Bezel
