PTFE oil additive
I was curious if anyone here has used an oil supplement containing PTFE. A fair number of years ago, there was a company QMI. I have used their gear treatment in the vintage car four speed trans and the '04 C5 six speed trans and I actually felt the product made a difference. The company is now Solid Start, located in FL and their products are marketed under the True Brand logo. I have read both pros and cons about adding PTFE to an engine but was looking for real life experience from someone here. I currently use Schaeffer oil in everything I own. Thanks for any information.
Regards,
Chas
Alternatively, some of the newer API SP oils meet GM4718M. API SP oils are specifically formulated for newer direct injection engines and they do a better job of controlling sludge, varnish and engine deposits, all while dealing with the extra heat from turbochargers. Pennzoil Platinum is an example of such an API SP oil that meets GM specs, but there are others. Additionally, Pennzoil Ultra Platinum not only meets GM's spec, but has additional friction modifiers not found in the regular Pennzoil Platinum oil. Perhaps something like this may be of interest to you?
I only mention Pennzoil because I recently saw this vid about this option:
Long story short, I'd suggest that you make an informed decision about engine oil, rather than pouring random stuff into your crankcase. Engine oil additive packages must be properly balanced, for all of the individual ingredients to do their job as expected.
One additive I have found that is legit and will help some things is Marvel Mystery oil. It can be used in oil or gas. It can clean up issues in the engine like injectors and lifter issues. I had some old times teach me about it and I used it to fix issues on engines.
About once a year I put some in the gas to clean the injectors and I wonder if it may help the sending unit issue in the Corvette.
I am not a snake oil guy and Mystery Oil is not snake oil.
I saved a 8,000 mile Corvair engine that had sticking valves. The engine has sat from 1968 to 1992 and once we put some in and then changed the oil again after running it no issues from then on.
Other wise just stick to good Synthetic oil.
As I understand it, Mobil-1 went through much the same discovery process. Getting rid of the sodium, dramatically reducing the calcium and going with a newer detergent package allowed the zinc to be much more effective.
It you have a flat tappet car Mobil One makes a 15 W 40 racing oil that has higher content zinc and phosphates that are enough to preserve the cam and rockers. Long term yes it could hurt a converter but that is nothing new.
Today it is more important to learn the content of the oil and you may need to adjust due to changes they are making.
FWIW, I recently was reading an STP bottle, and it specifically states that it contains ZDDP. I was interested, as I doubt that my lawn mowers have roller valvetrain, therefore they need the added zinc content.
The time has come to put our collective feet down and punish the sick bastards that torture us with this crap!
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. If would be better to live under robber barons than under omnipotent moral busybodies. The robber baron's cruelty may sometimes sleep, his cupidity may at some point be satiated; but those who torment us for our own good will torment us without end for they do so with the approval of their own conscience.
- C.S. Lewis
In Porsches it's infamous for clogging the oil sprayers
The oil companies employee fantastic chemists and engineers, if any of this crap in a can worked, it would be part of the native additive package
IIRC, PTFE is basically Teflon.......
Dexos is an example of where the automakers are trying to leverage their will on what is in oil.
