12 disk CD Changer will not eject cartridge
Old Feb 11, 2024 | 04:44 PM
MarMe's Avatar
MarMe
2nd Gear
Default 12 disk CD Changer will not eject cartridge
Hello all, know there is much discussion as these trunk mounted CD changers break a lot. In my new to me '99 Coupe, I tried to open the changer and it would not eject the cartridge, some click sounds but nothing after that. I took it out and took all the covers off, but could not see any obvious problem. I read an old post that said there is a small white lever that will manually release the cartridge. I did work, however the cartridge only popped up a a bit more flush with the eject door, but not enough to be able to pull it out at all. I pushed on it on is some but still will not eject. Any other ideas?
Also, has anyone hocked up anything else to the exiting wiring for the CD player? Thanks for any ideas.
Old Feb 11, 2024 | 05:06 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
You can have them fixed, but they cause a lot of electrical problems. Best to just toss it and go with Bluetooth music.
Old Feb 11, 2024 | 07:38 PM
MarMe's Avatar
MarMe
2nd Gear
Thanks for the input. I'm already inclined not to deal with it unless it was an easy fix. I'm already using a Bluetooth speaker I'll probably stick with it then.
Old Feb 11, 2024 | 08:02 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Same thing happened with mine. I ended up dismantling the entire unit to get the cds out and threw the pieces in the garbage.
The car audio section of the forum has lots of good solutions for replacement radios and speaker upgrades.
Old Feb 12, 2024 | 09:49 AM
yellow2007's Avatar
yellow2007
Lone voice of dissent here. I'm a believer in originality so I'd fix the changer. This is from digital corvettes website.
Look very closely, there is a small hole. Get something to push into that hole at the same time you open the door. It should try to eject the cartridge. Mine had cd holders that were all misaligned and had to be taken apart to save all 12 cd's. I eventually bought a almost new one off ebay for 100.00 bux. Works perfectly after just plugging it in. The head unit seen it right away.
Old Feb 12, 2024 | 01:39 PM
hyperv6's Avatar
hyperv6
If worse comes just take the top off the player and you can see in and get the parts out or to eject. Don't force but you often can get things back in line.
Old Feb 12, 2024 | 03:22 PM
grinder11's Avatar
grinder11
The Pioneer changer, like everything, had some really good ones, and some not so good. I never had any problems with mine in 24 years,136,000 miles. Went with a new HU last spring that plays a single CD, and has Sirius/XM and Android Auto. But I actually miss it. I agree with having it fixed. Can't remember the place in Texas that services them.
Old Feb 15, 2024 | 03:50 PM
bc6152's Avatar
bc6152
I took mine out of the '98 and sent it down to Dr. Don's in Huntsville, Texas. He replaced the innards and sent it back in about 2 weeks. I can't remember the exact amount he charged but it was around $350.00. I wanted the factory unit so went ahead and paid it. I reinstalled it and now 2 years later it's still working fine. BTW he does warranty it for life after the repair. Whose life I don't know... LOL.
If you can find a unit in good condition from another car for less that's an alternative. GOOD LUCK!
Old Feb 15, 2024 | 05:11 PM
hyperv6's Avatar
hyperv6
Has anyone mounted horizontal and saw any improvement.
To 12 disk CD Changer will not eject cartridge
