'04 LS1 heads question
Old Feb 14, 2024 | 08:39 AM
LannyL81's Avatar
LannyL81
Default '04 LS1 heads question
I have read that all '04s Corvettes came with LS6 heads....wondering if this is correct. And no I have not taken the time to pull a valve cover off to check the head part number on my '04....thought I would ask first.
Thanks,
Old Feb 14, 2024 | 09:38 AM
redzg's Avatar
redzg
Last three digits of the casting number are on a pad at the end of exhaust side of the head, visible with the valve cover on.
Old Feb 14, 2024 | 10:55 AM
Markolc1981's Avatar
Markolc1981
241 heads = LS1
243 heads = LS6.
You should easily be able to see it on the bottom right, just below the valve cover on the passenger side head without removing anything.
Old Feb 14, 2024 | 11:58 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Definitely not true. They all came with LS6 INTAKE MANIFOLDS, but not heads.
Old Feb 14, 2024 | 02:00 PM
LannyL81's Avatar
LannyL81
Since I read about the LS6 heads being on all '04s on the Internet....it has to be true.....LOL!!!
I did not know I could see the last three casting numbers without removing anything. Took a look-see and gee....... 241.....I am shocked!!!.....
I knew about the intake being the LS6 one. Would sure have been a $$$ saver if the heads were the 243s towards my project of pumping-up to LS6 horsepower.....oh well.....
Many thanks for the correct info.
Later
Old Feb 14, 2024 | 04:13 PM
Beast's Avatar
Beast
Spend some money. Get some AFR or PRC heads. You won’t be disappointed.
Old Feb 15, 2024 | 12:47 AM
Plenty of good aftermarket heads if you want to make a change.
Old Feb 15, 2024 | 07:35 AM
Prop Joe's Avatar
Prop Joe
I wish these were available in spring 2023 when I did my head/cam/header swap. LS6 style heads (64cc), CNC ported, all new casting, all new valves, guides, seals, springs, retainers... Made in the USA:
https://www.texas-speed.com/p-18424-...retainers.aspx
Old Feb 15, 2024 | 06:54 PM
grinder11's Avatar
grinder11
Later C5s also came with LS6 blocks. IIRC, this was started in the 2002 models. So, LS6 intakes-Yes. LS6 blocks-Yes. LS6 heads-Never....
Old Feb 15, 2024 | 09:03 PM
vette4fl's Avatar
vette4fl
Thats very reasonable price considering all the features. Any other comparable aftermarket heads would be $1,000 more.
Old Feb 18, 2024 | 08:05 AM
LannyL81's Avatar
LannyL81
Those Texas Speed Bralwer heads do look nice. Any recommendations on what rockers to use with them with an "LS6" cam?
Old Feb 18, 2024 | 08:44 AM
Prop Joe's Avatar
Prop Joe
I went with the BTR V2 rocker bearings modification with the stock rockers. The V2 version has a pressed on hardened race on the shaft to avoid wear like some have experienced with other brands.
https://briantooleyracing.com/btr-pr...kit-tk002.html
Or you can buy them already made:
https://briantooleyracing.com/ls1-ls...s1rkrs-16.html
Old Feb 19, 2024 | 08:49 AM
LannyL81's Avatar
LannyL81
Nice!!
To '04 LS1 heads question
