Exhaust help!
Old Mar 7, 2024 | 12:42 PM
YellowVinnieC5's Avatar
YellowVinnieC5
4th Gear
Default Exhaust help!
Hi, I am thinking of buying these straight pipes for my c5, but I don’t want to cut them when putting them in. How high do you think I’d need to jack the car to get them in, it seems easier because it’s without a muffler but I still am worried.
Do you guys think I’d be able to put these in with just normal jack stands?
Old Mar 7, 2024 | 01:04 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Find a local muffler shop - they shouldn't charge you more than a few dollars to do it.
Old Mar 7, 2024 | 01:07 PM
Trickskier's Avatar
Trickskier
Old Mar 7, 2024 | 01:15 PM
Missileboy's Avatar
Missileboy
if you try it on a jack, you'll need a 2 post and you'll need to be able to stand up. On a 4 post , you'll hit the lift when you try and rotate around and such so use a 2 post. Be prepared, it is gonna drone like a **** at normal highway speeds. Or do what the others have suggested. It is easier with mufflers as they can be removed.
Old Mar 7, 2024 | 01:59 PM
Stingroo's Avatar
Stingroo
That looks like someone cut some mufflers out of an existing setup and welded in a piece of pipe. They should have just put some clamps in - they already hacked it. Another cut won't hurt. haha
To Exhaust help!
