2000 Headlight Issue C5
Old Mar 10, 2024 | 09:17 AM
TARHEEL_VETTE's Avatar
TARHEEL_VETTE
Default 2000 Headlight Issue C5
My C5 had a problem with a driver side headlight coming up. I was able to use the manual dial to raise it. While that was happening I found that the rubber cover over the dial was not there? Then using the dial to raise the light the very small piece of plastic broke off.... Can anyone help me with either what that part is called or a picture of it or a Part #? Thanks so much...
Old Mar 10, 2024 | 09:50 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Time to change out the broken plastic gears and replace them with metal ones. Takes a little time and effort but isn’t a complicated job.
Old Mar 10, 2024 | 12:10 PM
TARHEEL_VETTE
Thanks I know they are plastic gears but they are not the problem.... On the right side of the assembly is a rubber cap as well and under that cap is a **** that you can turn and it raises and lowers the headlight. the rubber caps are gone and the ***** have a plastic torx that lowers and raises them. The rubber cap and the ***** are the parts i'm looking for...
Old Mar 10, 2024 | 01:15 PM
rrwirsi's Avatar
rrwirsi
Since your post said you had a problem with the headlight raising, if it still occurs after finding the parts you need, try disconnecting the headlight from the control module. Clean and make sure the connections are tight. That is what fixed my occasional headlight issue.
Old Mar 10, 2024 | 01:41 PM
TARHEEL_VETTE
Thanks for the reply, I will do that and if you know of the parts I referenced or see them let me know!
Appreciate your help,
Wayne
Old Mar 10, 2024 | 02:03 PM
hyperv6's Avatar
hyperv6
If you need the **** too contact Dino At Dino at Dino’s Corvette Salvage. He is good for odd parts most other places will not sell apart.
Old Mar 11, 2024 | 09:00 AM
Davcruz's Avatar
Davcruz
+1 to Dino's, you will pay for them but they are probably in stock. The rubber cover is not really needed, but I replaced a missing one as well.
Old Mar 11, 2024 | 05:25 PM
SilverC54me's Avatar
SilverC54me
The manual **** on the top of the headlight motor is not individually replaceable. You will need a complete headlight motor. If your car is a late 2000 or newer the motor is less than $100 each. If it is an early car best price I have seen is about $400. This is on Amazon.
Gary
Old Mar 12, 2024 | 07:36 AM
TARHEEL_VETTE
Gary
Gary,
Thanks so much that would explain not being able to find it individually! Really appreciate your jumping in!
Wayne
Old Mar 12, 2024 | 07:38 AM
TARHEEL_VETTE
Thanks so much this really hepled...
Wayne
Old Mar 12, 2024 | 07:44 AM
TARHEEL_VETTE
Wayne
I would add to all our friends...when the using the cap to manually raise the headlight, DON"T. Counterclockwise will raise the headlight and clockwise lower it but if it is alreadly down turning clockwise might break off the PLASTIC piece inside the cap Use a small torx after removing the cap. Works much better. it is crazy they use these small plastic parts even in the gears!
Thanks again Dave...
To 2000 Headlight Issue C5
