This is about my '04. Sometimes the driver's side mirror just moves on its own accord. I always use the same key fob (#1). Have set the mirror where I want it and pressed memory 1 button...done this several times. But still occasionally the mirror moves. I assume it does this on start-up and I just do not notice it.
Is this a sign that door control module or seat control module is losing bus communications or something?
Appreciate any insight on this one. Have searched but did not find this problem.
I assume the mirror is being moved by the motor as I have always been able to adjust it back using the motor. I would think if something was loose I would reach the end of the motor travel and not be able to adjust it back again.
Also always seems to go to the same position. I am going to try setting memory positions 1 & 2 to be the same.....perhaps even do #3 as well. See if that helps.
I have replaced the driver's side control panel, but the mirror did this before as well.
