Am i asking too much?
Old May 24, 2024 | 11:22 AM
Thebigdeal1970's Avatar
Thebigdeal1970
6th Gear
Default Am i asking too much?
Hello Forum,
I have a 2002 c5 automatic convertible all stock accept the the Corsa extreme Titanium exhaust. the tires are goodyear exilerate tires, I have a pretty simple question with performance mode turned on . from just sitting and stomping on the gas shouldn't I be able to break the tires or am I asking for too much .The reason I ask is there are those seldom times I wanna show off a little bit to friends and family but I get the most pathetic chirp when I stomp on it ( flashback to my teen 6 cyl caviler days) I literally have to brake tork ( I know its not good to do ) and let the tires spin up before it can at least not look so lame,
I tried new plugs and wires
Did i Buy a POS and something is not right or am I asking too much from an automatic c5?
Old May 24, 2024 | 11:47 AM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
Torque management in the computer kicking in to save the transmission when you “stomp on it “.
Old May 24, 2024 | 11:57 AM
Beast's Avatar
Beast
If you have the 2.73 gears in the differential, it won’t light up the tires from a dig. It’s not a POS, it’s just the way it is.
Old May 24, 2024 | 12:03 PM
Thebigdeal1970
6th Gear
How can I tell which gear in in my car? and what should I have put in ?
Old May 24, 2024 | 12:14 PM
Thebigdeal1970
6th Gear
doesn't that turn off in performance mode. if not is there a way to do that ? it's not like i will rip the tires every day
Old May 24, 2024 | 12:32 PM
hyperv6's Avatar
hyperv6
Did you put it in performance mode?
It will wake it up.
Burning off tires really means little. Corvettes are made to put the power to the ground.
Old May 24, 2024 | 12:43 PM
YellowZ06-427's Avatar
YellowZ06-427
Check your RPO codes would be the easiest if they are still stock.
Old May 24, 2024 | 01:50 PM
c5arlen's Avatar
c5arlen
Yeah... Get yourself a Dodge! 😂
Old May 24, 2024 | 04:45 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Old May 24, 2024 | 06:08 PM
captain vette's Avatar
captain vette
An auto trans with a 2.73 won’t do any good to light the tires from a standstill, yeah you’re asking too much unfortunately
Old May 24, 2024 | 06:54 PM
DDaaryl's Avatar
DDaaryl
I can easily answer the question because I have owned two 2002 verts. When I got both of these cars, they had older run flat tires. First the OEM Goodyear and later one had Michelin. I could easily spin the tires because they were hard and not sticky. When I replaced tires with Hankook V12's I had trouble breaking them loose even with the M6 transmission. Now I have an A4 with the performance axel and can easily break the tires loose at a standing stop with old Michelin tires indicating it is time for new ones. Havin the car hook up and go is better than doing burn outs and safer for handling. My guess is you have good tires.
Old May 24, 2024 | 08:34 PM
vette4fl's Avatar
vette4fl
Without a higher stall converter and/or SOME engine mods, it’s not going to smoke the tires. In stock form these cars will go high mph, but are designed to protect the driveline from torque shock from a standing start.
Old May 24, 2024 | 10:46 PM
jdmvette's Avatar
jdmvette
Night Owl for life
put in some 4.10s
Old May 24, 2024 | 11:05 PM
_zebra's Avatar
_zebra
the idea behind "performance mode" is to prevent wheel spin so as to maximize traction (and therefore speed). if you want to do a burnout, turn traction & stability controls off.
the high-geared rear end and automatic transmission are separate but equal detractors to your smoky dreams.
Old May 26, 2024 | 10:46 PM
Turning all the nannies off will help do what you want the car to do.
Old May 26, 2024 | 11:51 PM
Prop Joe's Avatar
Prop Joe
Differential final drive ratio will make a huge difference on how the car accelerates from a stop.. If you look at the SPID label on the glove lid...
3.15 is "G92" code "Performance" Gear ration on the Auto trans and is better off the line
2.73 is "GU2" standard rear ratio is the "Highway" cruiser gear
Std gear on the manual 6 speed cars was 3.42...
Old May 27, 2024 | 04:54 PM
Tyler_RN_EMT's Avatar
Tyler_RN_EMT
My Advice..... Should've gotten a Manual
Old May 27, 2024 | 05:07 PM
Beast's Avatar
Beast
Put an RPM diff in there with 3.73 gears and 3200 stall and you can light a 305 tire up whenever you want, or get some drag radials and launch that car.
To Am i asking too much?
