Possible C6Z shifter if the **** is angled slightly back when in neutral. Black base shaft looks oem.
I quite enjoyed my C6Z shifter for daily driver use. The angle was appreciated. With any oem shifter, be sure to check the tub. If the bearing has seal parts on the rear shaft or looks worn out and feels a bit of slop .... well, that's normal and all but you can also consider a TMODcustom tub to fix and eliminate the problem.
