Looking For Stroker Motor Owners
Old Aug 5, 2024 | 09:02 PM
deuceroadster2's Avatar
deuceroadster2
Default Looking For Stroker Motor Owners
I'm considering doing a stroker motor. Just curious who here is currently running one and what size? Would you do it over if you had to? Has it affected the streetability of your Vette?
Thanks for your input!
Old Aug 5, 2024 | 09:54 PM
jdmvette's Avatar
jdmvette
Night Owl for life
I think Clarence Carter might have one
Old Aug 5, 2024 | 11:38 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Forged 408 with 11 psi LSA blower.
Absolutely would do again.
Old Aug 5, 2024 | 11:39 PM
Mr. Black's Avatar
Mr. Black
Streetability is going to be more based on cam choice than how big the motor is.
Old Aug 6, 2024 | 06:52 AM
deuceroadster2
Is this the same C5 on YouTube posted by PNW Car Mods? If so, I've followed that build, pretty impressive. I can't bring myself to cut my cowl to fit a blower on though! Lol
Old Aug 6, 2024 | 07:54 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
383 with an A&A Vortech V3. 110% would do again... actually larger displacement N/A would be even better IMO.
Do it!
Old Aug 6, 2024 | 11:45 AM
Beast's Avatar
Beast
Let’s just say you pull your LS1 block, forge it to a 383, how about a nice .550 lift supercharger cam, keep the valve lift low for reliability and throw a supercharger on it, magnuson for the torque down low. How’s the reliability, all things being equal, built trans, diff, and TT, would you drive a 650 wheel horse C5 across country and not be worried? And yes I know, anything can happen, anything can happen on a stock car too.
Old Aug 6, 2024 | 11:52 AM
acroy's Avatar
acroy
^^ this
Both my C5s have had stokers; 402 and 427. Cam, tuning determine road manners.
Old Aug 6, 2024 | 05:51 PM
deuceroadster2
Do it!
Why do you say larger displacement N/A would be even better? You don't care for the Vortech or you mean more cubes WITH Vortech?
Old Aug 6, 2024 | 05:55 PM
deuceroadster2
Originally Posted by acroy
^^ this
Which block did you start with to get your 427?
Old Aug 6, 2024 | 06:38 PM
arthursc2's Avatar
arthursc2
I am on my second 408. First one was 10.2:1 with a 230s cam, will need to look at the specs. .600 lift both sides, stock LS3 top end with oversize intake valve, 1 7/8 header, 3" off-road X-pipe, 90mm tb, airaid intake, blah blah
Made 453whp and 451tq. The torque was intoxicating. It didn't matter the gear or RPM, throttle application lead to an instant torque hit that just pulled like a tuned diesel. It was... great. That motor lost oil pressure
So I am on my second 408 (planning to start it this Sunday)
11:1 comp, Summit 8721R1 cam 8721R1, Texas Speed Brawler CNC LS3 heads, same bolt-ons and intake as before. Really hoping to crack 500whp with 450+ tq
Old Aug 6, 2024 | 06:41 PM
Mr. Black's Avatar
Mr. Black
Yessir, that is me.
Old Aug 6, 2024 | 08:06 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
HPR 450ci
IDK the power of this engine but the previous combo made 594 whp/525 rwtq on 93. The 450 is 15" bigger, a few degrees difference in the cam and some throat work in the heads so it should make a little more power; not done tuning as I've only put 200 miles on it.
I am maxed out as far as I can go without an intake which isn't happening. Big power N/A is very expensive and I probably wouldn't do it again, if you can be satisfied with 550ish rwhp then you'll be ok.
If I were to do it all over again, I'd go boost and TT at that, likely 370-380 ish ci. Initially TT is more expensive but in the long run, it will be cheaper and the better route as you can use a lot less cam and have the valvetrain live without high dollar parts. It really depends on what power level you're looking for and what your dollar tolerance is. Big power N/A's rent is too damn high and starts to become racecar.
I wouldn't go SC boost due to the fact that you need to make about 100-150 more whp than a N/A car just to keep up with the NA car. In other words, a 700-750 whp SC car = a 600 whp N/A car (raced plenty of Sc ~700whp cars validating this). If you're doing it just to have fun, SC are the cheapest way to big power.
Old Aug 6, 2024 | 09:26 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
This is a great thread. I too am looking for power. I have a 2k with 124,000 on it and an auto. Looked at A&A as Andy's brother tiled my house in Florida, we talked quite a bit about it when he saw I had a C5. I know it is quick and easy however I hesitate putting that much more power into a higher mileage short block, and like mentioned I am a big fan of big torque. Grew up in the 70's when the 7+ liter giants ruled, one ride in a well tuned Buick GS when I was 14 scarred me for life in a good way. I would love to TT something but packaging looks like a nightmare, I am thinking NA big cube with what some would call a mild build. My first time dealing with an LS based engine, not caring about horsepower output what would it take to achieve 500 rwtq with a 6K redline.
Old Aug 7, 2024 | 07:36 AM
Bobbo76's Avatar
Bobbo76
I would prefer for my use to have a larger displacement motor that makes roughly the same power and maybe more RPMs than the added complexity of a supercharger. I frequently track my car so the added heat and complexity is a disadvantage. KISS method rules IMO.
That said aside from dealing with belt slip the A&A system is phenomenal and might be for sale in the coming months as I'm looking at a different set up... If I don't sell the car and start all over again
Old Aug 7, 2024 | 01:19 PM
acroy's Avatar
acroy
LS2
An intake? confused. Are you running OE Intake/manifold?
Old Aug 7, 2024 | 01:44 PM
arthursc2's Avatar
arthursc2
Low LSA cam, high compression, big cubes, lots of octane and timing. Have the exhaust and intake to support it, party on
To Looking For Stroker Motor Owners
Old Aug 7, 2024 | 04:46 PM
Millenium Z06
Moderator
LS2
MSD atomic. I consider an intake a Holley HighRam or a BTR, Performance Design etc. Anything thats not a restriction on a C5/6, MSD is still a restriction and maxes out around 630-650 whp on E85 NA.
HPR spec'd my cam based upon the intake/ intake restriction.
HPR's response to RPM range/cam
Intake, intake, intake. I know we have talked about it a bit before in the past but that MSD is going to set the limit of where that engine is going to make power. Now of course you want to keep it as happy as you can throughout the range but the intake (or total induction system) is going to be at some point your restrictor plate. That said, those intakes like to peak 6500-6800 or so. Never seen one peak higher than that.
MSD is better than stock but its not as good as people think, it was worth about 20rwhp for me. High Ram and Performance Design arre significantly better. Any NA car making power in the 7xx rw is using something other than what fits under the hood of a C5/6. I really question the claimed 640+ rwhp cars using an intake that fits under the hood. It simply cant flow enough air; ive seen people here use a NW102 infront of an MSD and still not pickup power which indicates that the intake is the restriction.
OP, all this minutia is what makes NA expensive and why I suggested boost rather than N/A . oure also going to need to do something with the drivetrain as well, its not going to be happy with that much TQ, esp the diff
Old Aug 8, 2024 | 05:49 PM
deuceroadster2
So just out of curiosity Millenium, what RPM range are you looking to build your next one for? Those Hi Ram intakes like high RPM.
Old Aug 8, 2024 | 05:56 PM
Millenium Z06
Moderator
Im not. I wanted to be able to pull through 7K RPM and not have to shift so soon, that was the context of the conversation with Anthony and myself with regards to the cam/intake. He got the cam spec dialed in right as the car pulls through 7K and doesnt nose over at 6500 like the previous gwatney cam did.
My point with regards to the intake was that big cube strokers need air and the under the hood intake is a restriction. Boost would be easier.
If I did this again, I'd go TT with a small 377-388 inch engine. NA is too much work/expense
