Replacement Shocks
Old Aug 23, 2024 | 05:38 PM
Jim B's Avatar
Jim B
Cruising
Default Replacement Shocks
Hi all - Apologize in advance as I suspect this has been discussed before, but.....I have a 2000 coupe with the Z51 suspension option. It seems the most recommended replacement shocks are Bilstein B6, Bilstein B8 and the 2013 C6 Z06 OEM shocks. Has anyone been able to compare back to back and rank these in terms of ride quality and wheel control? In terms of stiffness, I would like to stay close to my OEM Z51 shocks. I will say that I have driven a 2013 Grand Sport Convertible with the Z06 option and thought that had a great mix of ride quality and wheel control, but I am not sure if the convertibles came with the same shocks as the coupes.
Old Aug 28, 2024 | 12:43 PM
Joshclifford84's Avatar
Joshclifford84
I went from Z51 to C6 Z06 shocks and it is noticeably stiffer ride. 98 car. Although, they 100% serve the purpose I installed them for so its worth it for me giving up some ride comfort.
Also added the C6 Z06 sway bars, got rid of the body roll.
Old Aug 28, 2024 | 02:28 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
I had C6 Z06 shocks on my '99 C5 coming from F45, great upgrade. Best of all worlds.
Old Aug 28, 2024 | 05:57 PM
Lowend's Avatar
Lowend
Your shocks need to be paired to the suspension - specifically travel and spring rate. On paper, I'm not a huge fan of swapping C6 shocks which are designed for much stiffer springs.
I would encourage your to take a look at the Koni Sport shocks. Very well proven on these cars, specifically designed for the C5, lifetime warranty and externally adjustable for fine tuning
https://shop.koni-na.com/products/3013-1023sport
Old Aug 28, 2024 | 06:01 PM
Beast's Avatar
Beast
I won’t vote for the B8. To stiff for street driving. Unless you’re going for HPDE lap times, go ahead. I did the B6. I think they are pretty comparable to c6z06 shocks. Both are about the same price, I got the B6 for 100 a piece about 2 years ago. You can’t go wrong with either one. I did c6z51 sway bars as well.
good luck with your purchase, install, and improved handling. Only thing holding you back now is a street tire. Don’t overdrive your car either.
Old Aug 28, 2024 | 06:13 PM
Elektro's Avatar
Elektro
I really like the Fox Ridetech HQ. Two thumbs up. My car is comfortable on bumpy michigan toads and smooth and predictable on track. It may not be the fastest shock but making the car easier to drive means it is easier to go faster for me. I got them from stranoparts, he can get you the right shock for your need.
Old Aug 29, 2024 | 10:52 PM
The C6 Z06 shocks are a great upgrade for the C5. Reasonably priced too.
To Replacement Shocks
