Hood Latches
Old Sep 1, 2024 | 09:31 AM
huesmann's Avatar
huesmann
Default Hood Latches
Are the hood latches adjustable? My drivers side doesn’t usually latch with the passenger side, and needs a good slam to get it to latch.
Old Sep 1, 2024 | 09:49 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
There’s not much movement with the latch itself, but you can adjust the hood slightly back or forward with the two bolts that connect to the frame rails in the front. You will also need to detach the hood strut to reduce the tension.
Old Sep 1, 2024 | 09:58 AM
Fast one's Avatar
Fast one
The latches are adjustable however the rear adjustable rubber stops get hard with age making it more difficult for the latches to seat. The adjustable stops are supposed to compress some and apply a little upward pressure to keep the closed hood from rattling. It's also a good idea to solvent clean the old grease out of the latches and re-grease.
Old Sep 1, 2024 | 11:40 AM
rrwirsi's Avatar
rrwirsi
Since ownership, 10 years, my hood needs a energized push to close. I find the hood latches easier if I close it from the passenger side then the driver's. Weird.
Old Sep 1, 2024 | 06:17 PM
VERYSOON's Avatar
VERYSOON
THIS!!
I was having a problem with the hood latching down. Hit the latches with brake cleaner and new white lithium grease. Perfect.
VS
Old Sep 1, 2024 | 11:12 PM
To Hood Latches
