C5 Clutch Return Spring
Old Sep 6, 2024 | 10:06 AM
Compari76's Avatar
Compari76
2nd Gear
Default C5 Clutch Return Spring
Does anyone know where I can get a C5 Clutch Return Spring (Part #10376347) as they are now discontinued, or does anyone know an equivalent part number that will work? I am in Sudbury, Ontario Canada.
Old Sep 6, 2024 | 10:21 AM
StingrayRebel's Avatar
StingrayRebel
I have one, pm me
Old Sep 6, 2024 | 11:15 AM
Compari76's Avatar
Compari76
2nd Gear
How do I do that? Sorry, I'm new to this forum
Old Sep 7, 2024 | 03:21 AM
jdmvette's Avatar
jdmvette
Night Owl for life
do you have an oh-oh-oh o'reilly auto parts up there?
https://www.oreillyauto.com/detail/c.../acd0/10376347
Old Sep 7, 2024 | 07:39 PM
zeevette's Avatar
zeevette
You talkin' about the kind of U shaped spring? If so, that's not a return spring, it's there to "assist" pushing in the clutch and keeping the pedal at the top of it's travel. Mine broke in 2009 or so and I haven't replaced it.
Old Oct 6, 2024 | 01:49 PM
2reverb's Avatar
2reverb
Amazon
Amazon Amazon
Old Nov 10, 2024 | 04:16 PM
errosica's Avatar
errosica
Cruising
The clutch return spring in my 2003 Corvette failed yesterday. Looks like its part number 12555205. Can't find it anywhere. Any tips?
At the same time, the (solid) check engine light also came on and the car will no longer start. I feel like it has to be related to the spring, but I don't understand how it could be since there are threads on here about people removing their springs on purpose.
Old Nov 12, 2024 | 02:57 PM
JHrinsin's Avatar
JHrinsin
This is where I got mine at a couple months ago, but it looks like they are now out of stock as well. Maybe check with the Corvette recyclers?
https://www.theautopartsshop.com/sku/gm-genuine-parts-clutch-pedal-spring-acd12555205d
Old Nov 12, 2024 | 03:03 PM
JHrinsin's Avatar
JHrinsin
Not sure why, but the 2004 C5 and the C6 used a different spring p/n 10376347. I personally do not know if you can use these spring in place of the '97-03 unit.
Old Nov 14, 2024 | 07:38 PM
ChetS's Avatar
ChetS
I'm looking for one too. Willing to purchase.
Thanks Chet
Old Jan 15, 2025 | 09:32 PM
FiberGlassKid's Avatar
FiberGlassKid
I have the 12555205 spring in my 2007 since it was new. it is not reccomende for racing but for every day driving it's great. It just doesn't engage the clutch fast enough for speed shifting. The stock one was too stiff so i changed it
Old Jan 16, 2025 | 11:33 AM
JHrinsin's Avatar
JHrinsin
After doing more reach on these clutch pedal assist springs, it seems the the C5 spring was a popular swap for the C6 folks. They did not like the clutch pedal feel with the stock C6 assist spring so a lot of them backdated to the C5 spring, which may have contributed to the fact that the C5 spring is now out of stock, discontinued and hard to find.
Old Jan 16, 2025 | 11:48 AM
helga203's Avatar
helga203
is this what you need??? This is from 99
The springs so cheap just buy it.
Old Jan 16, 2025 | 11:52 AM
hyperv6's Avatar
hyperv6
https://www.gmpartscenter.net/oem-pa...gSmG8z_mcseEfQ
If you just Google this you will find a number of places that have these. Even Amazon.
Yes the C5 is lower tension than the C6 and many swap but avail on both are the same. They will interchange. I just did one a few months ago on a C6.
I would recommend running the spring to make sure the clutch is not slipped and often including the car I just put the spring on was smoother and quieter. The C6 was making noise and the pedal felt like something was wrong with vibration.
Old Jan 16, 2025 | 10:49 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i did the opposite and put a c6 spring in my c5
Old Jan 17, 2025 | 01:03 AM
USAZR1's Avatar
USAZR1
You're such a rebel.
Old Jan 30, 2025 | 08:31 PM
ChetS's Avatar
ChetS
Link doesn't work,
To C5 Clutch Return Spring
Old Apr 12, 2025 | 03:51 PM
FiberGlassKid
/www.ebay.com/itm/376143699283? Therev is one on Ebay right now
Old Jul 18, 2025 | 11:33 PM
vette4fl's Avatar
vette4fl
There are different springs on the 2004 vs 1997-2003, so be careful when buying.
The 2004 shares a heavier spring with the C6. The earlier C5’s used a smaller/lighter spring.
The spring being sold on the forum(see previous post) is small like the earlier C5 springs, but lighter yet by virtue of a slightly thinner material.
Old Oct 21, 2025 | 09:41 AM
jacks2005's Avatar
jacks2005
8th Gear
Default 10376347 Clutch spring
Does anyone have one of these? I can't believe, this simple part is so hard to find.
