Door hinges lube
Nov 16, 2024 | 12:41 PM
Door hinges lube
What are you guys using, I’ve been told not to use WD40
Popular Reply
Moderator, Tech Contributor
I’ve always used white Lithium grease.
Nov 16, 2024 | 01:12 PM
Nov 16, 2024 | 03:31 PM
Quote:
Originally Posted by
C5 Diag
Nov 16, 2024 | 05:04 PM
Nov 16, 2024 | 06:12 PM
White lube normal use.
PB blaster to free up hinge and roller then lube with white lithium grease.
Nov 16, 2024 | 07:32 PM
Nov 16, 2024 | 07:59 PM
WD is not a lubricant
Nov 16, 2024 | 09:03 PM
Yamalube Marine Grease is my go-to. Otherwise white lithium grease. Definitely not WD-40.
Nov 16, 2024 | 09:38 PM
walleyejack
Nov 16, 2024 | 10:44 PM
Yah... Dont use WD unless it is stuck/frozen.
I use Tri-Flow on many things. I have both drip bottles and the aerosol versions. The stuff works great on my C5 hinges. Drip or spray on pivot points of hinge, wipe off the excess.
The other lube I would recommend would be Corrosion X or ACF-50. Both are penetrating, wicking, great anti corrosive lubricants.
Nov 16, 2024 | 11:17 PM
By far....................the best thing to use is Lemon Pledge. Spray it on and wipe off the excess and not only is it lubed , but looks great.
Nov 17, 2024 | 08:18 AM
ztheusa
are you kidding?
Nov 17, 2024 | 03:39 PM
Geeze
One should use nothing but... light weight sewing machine oil on one's cheirshed C5 door and hood hindges!...gonna be the very best job one may do for ones Corvette ! A very important chore... lubing ones hindges... It will not be difficult in locating sewing machine oil... even in the boondocks of Montana women sew!... Well.. Some do! 🙄
Nov 17, 2024 | 03:54 PM
Nov 17, 2024 | 03:59 PM
Good Grief !!! anything is better then nothing
Nov 21, 2024 | 07:06 PM
I use motorcycle chain lube. It goes on thin allowing it to get into the hinge and thickens up.
Nov 22, 2024 | 08:11 AM
U.S. Air Force
St. Jude Donor '05 thru '26
C5 Diag
I also great product!
Nov 23, 2024 | 08:16 AM
How is "grease" going to make it's way into the hinge pins????
Nov 23, 2024 | 10:00 AM
leadfoot4
That's why I like marine gear lube. Penetrates and persists.
Nov 23, 2024 | 05:35 PM
leadfoot4
That is why "old school" Lemon Pledge is so good.
