Lost a piece
Old Nov 16, 2024 | 08:47 PM
Coyote's Avatar
Coyote
Default Lost a piece
In cleaning my intake air filter today, I seem to have lost a clamp that those on a hose which attaches to a tube on the left side (drivers side) of the air box housing. No freaking clue where it went, I assume it slid down the house into the abyss when I was moving stuff around. I put the hose back on the tube of the air box and it is on there pretty darn tight. I will look for a replacement clamp, but just wanted to make sure it would still be okay to drive until then.
Old Nov 16, 2024 | 09:00 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
You'll be fine. I'm assuming it's the hose for the air pump? If it's fitting tight like you said, you'll probably never need one anyway.
Old Nov 16, 2024 | 09:42 PM
I would think that if it is tight, you will be fine until a new clamp can be installed.
Old Nov 23, 2024 | 11:31 PM
3sACROWD's Avatar
3sACROWD
I can save you some time. If you're talking about the AIR hose (about 1"diameter), you DIDN'T lose a clamp. It doesn't have one. Hopefully you haven't been losing sleep over this as I see you asked the question a week ago with no definitive answer. ENJOY your car.
To Lost a piece
