Fob
Old Nov 25, 2024 | 04:02 AM
Greg Brough's Avatar
Greg Brough
1st Gear
Default Fob
Hi got a 99 c5, key fob not working, car didn’t come with one, been through the reprogram process but when press reset ,fob training doesn’t appear, just blank screen, where to from here, any help appreciated
Old Nov 25, 2024 | 04:53 PM
bookyoh's Avatar
bookyoh
Is this the programming procedure you used?
!. Turn ignition on.
2. Turn radio off.
3. Press DIC RESET button.
4. Press OPTIONS until display is blank.
5. Press and hold RESET for 3 seconds.
6. Press OPTIONS until FOB TRAINING displayed.
7. Press RESET to begin programming sequence.
8. Simultaneously press and hold LOCK and UNLOCK buttons on
fob for 13 seconds. Message will appear on DIC when remote is
programmed.
9. Turn ignition off and remove key.
10. Test remote.
If so, did you buy the GM fob for the ‘97-‘00?
