[Z06] Anyone using a C6 AC compressor on their C5?
The C5 compressor is a rear mount for the lines, but it looks like the C6 style is side mount.
I'm running Borla XR1 long tubes and I'd really like to use the new ac compressor, if possible.
Has anyone made it work?
Maybe switching to C6 ac lines?
Pic for reference:
The control valve in the back of the compressor may be a different setting between the 2 compressors. There should be a dab of paint on the exposed end. If they are the same color paint, you are good to go. If they are different, you will probably want to use the control valve from the C5.
The C5 uses a 7 cylinder variable displacement compressor called a V7. The C6 uses a newer design called a 7CVC, also a 7 cylinder variable displacement compressor.
That's exactly what I needed to know!
