C5 Approach Angle
Old Feb 17, 2025 | 12:00 PM
RMurray4's Avatar
RMurray4
Default C5 Approach Angle
Hello - first time poster...
I am inheriting/buying my dads 1999 C5 coupe. The car is all stock, no modifications.
I am concerned about the approach angle of my driveway (live in very hilly kentucky).
Has anyone computed the maximum(?) approach for this car without scraping the bumper. (I figure the air dam will take a hit)
Old Feb 17, 2025 | 12:10 PM
Missileboy's Avatar
Missileboy
I don't have a picture of mine, but I have a steep ~45degree angled curb to get up on my driveway off the street. If I come up and enter my driveway (with wheels straight) at a 45degree angle, I can get both wheels up on the driveway with no scraping, then I just turn the wheel and drive up and on. When I leave, I have to back down and the minute my rear wheels are "down" the curb, I straighten my wheels as I am ~45degrres angled already and roll as slow as I can down off the curb, and usually no scraping and sometimes just a small bit of the air damn scraping, not bad but I still hate it!
Speed bumps, I slow to a crawl and again, angle my steering to come up and over and then straighten up. I have no issue but if I hit them at 5mph? no bueno-
Old Feb 17, 2025 | 12:15 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I don't have any specific numbers to give you, but keep in mind GM actually designed the front of this car knowing it was going to hit the ground at times.
It can handle more than you might think.
I live on a completely flat surface street with completely flat driveway with a 2.5 inch or so asphalt curb separating the two and my car drags the airdam coming and going. That being said, my car is lowered down probably 1 to 2 inches front and rear.
If your dads car is still at stock height you can get over some pretty tall stuff as these cars stock tend to sit like a 4x4 lol.
Old Feb 17, 2025 | 12:37 PM
Ltngdrvr's Avatar
Ltngdrvr
The air dam is made of very flexible plastic, made to survive scrapes, and cheap enough to not break the bank if you tear it up and have to replace it.
But, it's too bad that Chevy didn't come up with the idea of the front end lift, like is offered on the C8, a long time back.
Old Feb 17, 2025 | 01:13 PM
RMurray4's Avatar
RMurray4
Default Thank you!
Thank you for your help!
Old Feb 17, 2025 | 03:32 PM
Dads2kconvertible's Avatar
Dads2kconvertible
I seem to recall 11 degrees or less is needed for ramp incline such as 'what ramps to I need so I can drive the car onto them'.
Old Feb 17, 2025 | 04:09 PM
hyperv6's Avatar
hyperv6
The black air dam will scrape. It is made to wear and be replaced.
The bars up front are not to scrape nor any painted surface.
The way in is on an angle and at time you may need to move gravel or put boards down to lift the car up.
Old Feb 17, 2025 | 06:01 PM
Eliot Ness's Avatar
Eliot Ness
Welcome to the forum! I also live in KY and hills are not a problem, just steep and rapid inclines like driveways and speed bumps. These cars are 20+ years old and have survived many inclines and scrapes. Just be careful and you'll be fine.
Old Feb 17, 2025 | 07:01 PM
hyperv6's Avatar
hyperv6
I would not lower till you know your limits. In my area lower is not good.
Old Feb 18, 2025 | 12:55 AM
I have a moderately steep entrance to my driveway and when I had my C5 I approached the entrance at approximately a 45* angle. It would occasionally scrape the air dam, but never scraped the radiator support bars nor the painted underside of the front fascia.
Old Feb 18, 2025 | 09:28 AM
Slick61's Avatar
Slick61
be glad you're not lowered/slammed... just come in at an angle & you should be fine. Mine had the Fat Daddys on the front when I bought mine, and am SOOOO glad it had them.
Old Feb 19, 2025 | 02:16 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
There is no magic angle.
Often what you will hear is the plastic air dams scraping which provide a sort of warning. They are entirely replacable. They can also be trimmed a bit if desired.
The only real risk is the underside of the nose and the lower radiator mounts. Some put plastic skid plate covers on those bars. I have always preferred the Big Momma skateboard wheel mounts instead. They save the nose in general while also being a good audible if you make contact. Additionally, should you ever need to be flat bedded they likewise save the nose and make the drivers happy as they absolutely aid in getting the car up and keeping the nose clear.
You will learn the car in time. A few scrapes down under the nose where no one sees them is common.
Old Feb 19, 2025 | 06:13 PM
Alley Oop's Avatar
Alley Oop
I've got a steep driveway and although I cut in at 45*, I was still scraping the air dam. Got tired of hearing the scrape so I reduced the depth by about 1 inch.
Got rid of the scrape and didn't affect the cooling.
To C5 Approach Angle
