Lifts. 2 post vs 4 post
Old Feb 24, 2025 | 06:50 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Default Lifts. 2 post vs 4 post
Starting the plans for my shop build which will include a car lift. The shop will appox be 40 x 60 with a 10' wall. I know many here have both 2 and 4 posts, which is preferred and why? TIA, Charles
Old Feb 24, 2025 | 07:34 PM
Necron's Avatar
Necron
I personally went 2-post since I work on all my vehicles. If I was just wanting more storage then I would of gone 4 post.
You can also get a 4 post with front or rear jacks so you can still work on suspension but I still feel that is tougher then just using a 2-post.
I noticed you said 10" tall which is still pretty short. My Forward 10k lift needed 12.2" ft clearance (I went with 13" before the roof structure) but I wanted to be able to fully stand since I'm 6'2.
Old Feb 24, 2025 | 08:07 PM
hyperv6's Avatar
hyperv6
Yes two post work, 4 post storage.
Make sure to understand all clearances like doors and choice of door openers. Many forget the added costs in many garages.
Old Feb 24, 2025 | 09:49 PM
zz28zz's Avatar
zz28zz
Yep over-head doors were extra with my metal building (shop). Need 2 feet above the door opening for a roll-up door to fit. Make sure slab is 6"+ thick especially with a 2-post.
Old Feb 24, 2025 | 11:21 PM
Rwdirtbke's Avatar
Rwdirtbke
Agree with the others. If it's a shop where you're constantly working on cars then 2 post is best. If storage then 4 post. However I will say that 4 post could be a good hybrid. My dad has had a 4 post for about 20 years. It's been used a ton, both to store cars and work on them. Right now the C5 is currently on the 4 post with the entire suspension torn apart getting new bushings. Yes it takes a bit more effort to get it all jacked up on the 4 post but it definitely can be done. Also the 4 post is moveable which I'm my dad's case is very valuable. Just my $.02
Old Feb 24, 2025 | 11:31 PM
CamarosRus's Avatar
CamarosRus
Ten Foot Wall...................use Scissors or Cathedral Trusses so you can place 2 post lift in the center and
have HIGHER than 10 foot clearance
Old Feb 25, 2025 | 06:59 AM
cdee63's Avatar
cdee63
Thanks. 10' wall however rafter roof so no flat ceiling. Staying up late I have decided a 4 post is best for me. I like the storage ability under it, from what I can see my set of QJ's fit on the runways perfectly for doing suspension and wheel work. The fact I can move a 4 post around was the selling point vs a 2 post.
Old Feb 25, 2025 | 08:00 AM
eric22's Avatar
eric22
Or you can get one of each like I did!
Old Feb 25, 2025 | 10:10 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
I don't like 2-post lifts because they are very difficult to lift some vehicles, like GM trucks that have a stepped frame. Plus, 2-post lifts are not safe in areas that have earthquakes. I would have never thought I'd say that living in Virginia, but we've had several in the last several years.
I have a 4-post lift, for working on all of my vehicles. AND I have the air-operated rolling center jacks so I can lift the vehicle to remove wheels/tires, axles, brakes, etc. etc.
No description available.
Old Feb 25, 2025 | 11:51 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I'm in the same debate. I'm also thinking 4 posts and QJs to have best of both.
I only have 9'6 ceilings. There are a few baseplate 2 posts that will fit in my garage, but I question the concrete slab depth too... so 4 post is probably what I will also do.
Old Feb 25, 2025 | 12:11 PM
cdee63's Avatar
cdee63
Yes, dummy me didn't realize a 4 post could be moved. Like mentioned that fact was the deal clincher for me. Now I just have to build the shop to put it in first.
Old Feb 26, 2025 | 09:46 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
It's easier to make a four post work when doing repairs and maintenance than it is to make a two post work for storage. Plus, I've seen way too many failed 2-post lift videos on You Tube.
Old Feb 26, 2025 | 02:01 PM
99FRC Newb's Avatar
99FRC Newb
I saw a neat garage door opener that mounts to the side of the rail. It definitely gives more clearance to raise a vehicle.
https://www.liftmaster.com/elite-ser...ener/p/98032MC
Old Feb 26, 2025 | 02:27 PM
frodo84's Avatar
frodo84
Uneducated autodidact
I have a four post, I moved it but I found that once I decided where it worked best I bolted it down. Made me nervous "swaying" when pulling on the vehicle at height. Just saying, I don't think they get moved a lot once purchased.
Old Feb 26, 2025 | 03:10 PM
633BR's Avatar
633BR
That's what I had installed before adding my 4-post lift last month. Works great, and much quieter than the standard ceiling mounted version.
Mine is not bolted down, and it doesn't sway or move with a vehicle on it.
Old Feb 26, 2025 | 04:37 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
If you go with a 4 post, get a set of two sliding or rolling lift jacks; they are not cheap but they will allow you to lift the car off the lift so you can do brakes, exhaust, etc. A 2 post is definitely better for working under the car but I have been able to do whatever I need underneath with the 4 post and the lift jacks.
Old Feb 26, 2025 | 10:02 PM
vette4fl's Avatar
vette4fl
CD, here’s a video about setting up a four post (with the sliding lifts) in a shop about the size you’re describing. I’ve watched this guy use the lift and how the sliders are used on his projects.
Ps. You might want to start a thread on your shop build and lift install just to entertain us 😀
To Lifts. 2 post vs 4 post
Old Feb 27, 2025 | 08:29 AM
cdee63's Avatar
cdee63
My neighbor had this installed on his new garage, he called them "sidewinders".
Thanks for all the input fellas. It won't be for a bit but I think a shop build thread would be good, that way I can pick other peoples brains here on how they set theirs up.
Old Feb 27, 2025 | 10:38 AM
Too-Fast's Avatar
Too-Fast
I have these jackshaft garage door lifts installed on both my garages; they work great and are used when you need to lift the door tracks to gain more space overhead.
Old Feb 27, 2025 | 04:31 PM
zz28zz's Avatar
zz28zz
I've got a Liftmaster jackshaft opener on my 10X10 roll-up door. Hasn't missed a beat in over 10 years. If you go with a metal building, the range of the opener remote is kinda of limited. I gotta be within abt 30 ft of the door to open it. Think they also make one with a batt to open door when power is out.
