Factory Head Unit 3D Printed Control Knobs
Old May 8, 2025 | 03:43 PM
WWFRC's Avatar
WWFRC
Default Factory Head Unit 3D Printed Control *****
While taking apart the factory head unit to install LED lights, I managed to lose one of the metal sleeves that sit inside of the tuning/volume *****. Unable to find a replacement metal sleeve by itself online, and with replacement ***** over $20 for a set, I decided to quickly draft up a some replacement ***** that could be 3D printed and would go directly onto the potentiometers on the factory radio without the metals sleeves. While they would look nicer with a resin printer, they turned out pretty good, and the cost of material beats the online options by a longshot!
A full set would be:
(1) Volume
(1) Tuning
(4) Fade/Base/Treble/Balance
Pictures are below, if anyone wants the .stl files, PM me your email address and I can send them over. I would recommend printing one to start to make sure it fits the potentiometers correctly. I had to adjust the size of the hole a couple times, and every 3D printer is a bit different. I also found that the potentiometers were slightly different form one another as well. I can adjust the hole size fairly easily if it doesn't fit yours.
Old May 8, 2025 | 06:48 PM
redzg's Avatar
redzg
What software are you using? Been trying FreeCad but it is not intuitive.
Old May 8, 2025 | 09:20 PM
nitromainia's Avatar
nitromainia
Nice! Thanks for sharing
Old May 9, 2025 | 12:01 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Cool idea, I have a printer but no CAD experience. Will need to change that and learn sometime.
Old May 9, 2025 | 09:09 AM
WWFRC's Avatar
WWFRC
I made these using Tinkercad, which is the educational/hobby CAD web-based software from AutoDesk. I find it easy to use and very intuitive. It is also free and web-based, but of course it cannot be used for commercial use.
It is pretty limited in functionality, but plenty good for 3D printing.
Old May 9, 2025 | 04:34 PM
redzg's Avatar
redzg
May have to investigate. Not that I'm old, but I've been using AutoCAD since it was on 5.25" floppies. Single sided at that.
Old May 10, 2025 | 12:04 AM
vette4fl's Avatar
vette4fl
So, after your time and cost of materials, how much money do you reckon was saved?
Im not too familiar with the details of the 3D printing.
Old May 10, 2025 | 12:44 PM
Fast one's Avatar
Fast one
What material did you use?
Old May 12, 2025 | 07:56 AM
WWFRC's Avatar
WWFRC
I had a buddy print them, I believe he used PLA on his Ender 3 Max. I'm sure they would look much smoother with a resin printer, I am thinking I am going to buy one soon.
Old May 12, 2025 | 11:40 AM
Fast one's Avatar
Fast one
PLA doesn't hold up well in car interiors because it cold flows when temperatures rise. I've had some small interior car parts remain usable while larger ones distort too much. Other materials such as ABS tolerate heat better but are more difficult to print.
Old May 12, 2025 | 01:58 PM
WWFRC's Avatar
WWFRC
Cost online for a set of volume/tuning ***** is ~$35, cost of material was probably only a few bucks, if that.
Time wise it was probably not worth doing this just for the one set (probably ~1 Hr. to make/adjust all three versions), but now I can print more in the future if I lose/break them. Plus others can save some money as well.
Old May 12, 2025 | 01:59 PM
WWFRC's Avatar
WWFRC
That is good to know. He doesn't like to use any other materials since he is printing indoors without ventilation.
When I have a location to do so (in ~2 months), I want to get a resin printer to make more visually appealing prints.
Old May 12, 2025 | 07:15 PM
Nice job and now you don’t have to worry about those parts becoming extremely hard to find.
Old Jul 5, 2025 | 02:44 PM
Ksanders6226's Avatar
Ksanders6226
1st Gear
Default STL File
(1) Volume
(1) Tuning
Hey buddy, I would love to have that file, if you dont mind. I tried to PM you and it wouldn't let me for some reason. Email is EnoughKreations@yahoo.com. thanks in advance!
Old Jul 9, 2025 | 07:46 AM
WWFRC's Avatar
WWFRC
Sent.
Old Jul 10, 2025 | 12:58 PM
f6john's Avatar
f6john
What online vendor is selling these?
Old Jul 10, 2025 | 03:53 PM
WWFRC's Avatar
WWFRC
There are quite a few, some are complete sets some are only partials:
https://www.zip-corvette.com/97-04-r...RoCVQUQAvD_BwE
Amazon Amazon
Amazon Amazon
To Factory Head Unit 3D Printed Control Knobs
