OEM Radiator ??
Old May 13, 2025 | 11:25 PM
LannyL81's Avatar
LannyL81
Default OEM Radiator ??
Just removed the radiator today out of my '04 Vert. I am wondering if it is original or at least a GM replacement as there are no auto trans lines connections.
When looking for a replacement radiator, I have found that all of them have connections for the auto trans lines.
Is there a replacement radiator (non DeWitts) that does not have these connections?
Old May 14, 2025 | 07:55 AM
redzg's Avatar
redzg
Nope. Well, no GM or stock style replacements. I have a genuine GM 52470606 in the shed. Bought from GM Parts Direct. Fittings and cooler. Same radiator as the AC Deco 20889. MM6 car, so original had no fittings and no reduction in cooling capacity from a transmission cooler.
I put in a used DeWitts, can’t speak for the other aluminum tank alternatives.
