Harmonic Balancer Replacement
Old Jun 14, 2025 | 02:08 AM
GMII99's Avatar
GMII99
Default Harmonic Balancer Replacement
Looking to replace the harmonic balancer and wanted to know what’s a good one to go with? I was looking on Summit and ATI has several different ones, what are a few to consider? Anyone with the Trickflow balancer?
Old Jun 14, 2025 | 02:22 AM
Smoken1's Avatar
Smoken1
A lot of people use the Summit racing C2501
I use the ATI or go cheap with the Powerbond PB1117N but, definitely get a new front seal and get the ARP bolt
Old Jun 14, 2025 | 08:22 AM
SideOfTheRoad's Avatar
SideOfTheRoad
I recently changed mine for the Powerbond PB1117SS along with the ARP bolt and new crank seal. I'm pretty happy with it.
Old Jun 14, 2025 | 08:36 AM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
*Unpopular Opinion Alert* but, when I had the balancer changed on my ‘99 a couple years ago, I did it at the dealer, was under $1k, and would be covered with a 2-year warranty.
Old Jun 14, 2025 | 08:40 AM
Ltngdrvr's Avatar
Ltngdrvr
How will you be using the car?
Big power mods on the engine, extended high RPM use?
Old Jun 14, 2025 | 08:51 AM
hyperv6's Avatar
hyperv6
Use the Summit. It is more than you will ever need with the SFI rating. It cheaper than the ATI and it will not fail agsin like Powerbond or the factory one.
Trick Flow is the same as summit just black and more expensive. Same SFI rating.
In the performance parts industry you generally avoid cheaper but often the same mfg will make the same parts and they are sold at different prices. The Summit one sells at high volume so they can charge you less and still be a top quality unit.
Old Jun 14, 2025 | 09:58 AM
GMII99's Avatar
GMII99
Great info, thanks!
Old Jun 14, 2025 | 10:00 AM
GMII99's Avatar
GMII99
Only power mods I’m looking at would be cam and full exhaust down the road. Mostly just cruising and having with it. No road course or strip racing.
Old Jun 14, 2025 | 10:01 AM
GMII99's Avatar
GMII99
Happen to have part # for quality crank seal?
Old Jun 14, 2025 | 10:58 AM
Ltngdrvr's Avatar
Ltngdrvr
Then you don't need to spend the money on something like the ATI, a basic balancer will do just fine, but if you want a little extra protection then the Summit Racing unit mentioned is more than you will ever need.
Is the OE balancer bad on it now?
Otherwise I wouldn't even fool with it until it needs it.
Old Jun 14, 2025 | 11:08 AM
pjdbm's Avatar
pjdbm
[QUOTEwill not fail agsin like Powerbond or the factory one.
][/QUOTE]
I didn't know that the Powerbond failed
Old Jun 14, 2025 | 11:43 AM
PerryKing's Avatar
PerryKing
2020 C6 of the Year Finalist - Modified
I went with the ATI. Piece of mind that I will NEVER have to do it again. I would suggest to do the cam at the same time. Everything will have to come back apart when you do the cam. Not an overly complicated job, just a PITA removing the steering rack.
Old Jun 14, 2025 | 12:30 PM
GMII99's Avatar
GMII99
It has a little wobble going on. Rather do it now before it does any damage.
Old Jun 14, 2025 | 12:38 PM
hyperv6's Avatar
hyperv6
I didn't know that the Powerbond failed[/QUOTE]
I have done warranties at work.
Old Jun 14, 2025 | 12:43 PM
hyperv6's Avatar
hyperv6
Witness mark it.
This way you can tell if it really is failing or not.
Yes replace the front seal. ARP bolt, if you have high miles might consider the oil pump. Same on water pump. Also do the belts. Check front cover for leaks.
You may not need all that but at higher miles now us the time.
ATI if you are going to do hard racing and modification.
Summit if you are remaining stock or mild mods like a cam etc.
Stock or power bond if you are selling the car.
Old Jun 14, 2025 | 01:18 PM
SideOfTheRoad
I went with a GM crank seal: 29602.
Old Jun 14, 2025 | 08:08 PM
cdw's Avatar
cdw
put a power bond on in Feb. everything good.
Old Jun 15, 2025 | 12:43 AM
GMII99's Avatar
GMII99
To Harmonic Balancer Replacement
