Super Glue removal
Old Jun 14, 2025 | 01:54 PM
CanWeBeBFFs's Avatar
CanWeBeBFFs
3rd Gear
Default Super Glue removal
Hey Guys,
I bought a c5 and am doing paint restoration, but the genius last owner had those "corvette" letters in the slots and they were falling off... so i removed them but behind the stupid O he used freaking super glue. I used the 3m adhesive remover to get everything else off the other letters but its not working on the super glue its like glass. any ideas I'm frustrated af. thank you in advance
Old Jun 14, 2025 | 02:03 PM
gtrslngrchris's Avatar
gtrslngrchris
Anything that will dissolve super glue is probably going to damage the paint. The number one thing I would want to use is acetone and that's definitely not good. CA glue is usually brittle unless it's a rubber formula or something which is usually woodworking related or similar so you may have some ability to chip away at it very carefully. Hopefully someone more knowledgeable than me will chime in with something I don't know about yet.
Old Jun 14, 2025 | 02:29 PM
Ron71's Avatar
Ron71
You might have luck trying to gently chip away the glue with a plastic razor blade. You will need to be cautious though. Worst case scenario, you could buy some new domed letters
Old Jun 14, 2025 | 03:21 PM
Ltngdrvr's Avatar
Ltngdrvr
Yeah, anything that will remove the super glue will remove the paint, and likely damage the urethane of the bumper too.
I would also suggest a new set of letters, in a color that you can live with.
Old Jun 14, 2025 | 03:51 PM
CFight's Avatar
CFight
Heat
Old Jun 14, 2025 | 09:28 PM
hyperv6's Avatar
hyperv6
The norm for removing the glue is acetone. Or fingernail polish remover as it is known.
Some paints react some not so much. You can rest in a hidden place. Tread carefully.
Old Jun 14, 2025 | 10:53 PM
RedC5's Avatar
RedC5
Try lacquer thinner - I used today on my car paint to remove a touch up blob and no affect on clear coat. From AI:
Yes, lacquer thinner can be used to remove dried super glue, especially from hard surfaces. It acts as a solvent, breaking down the adhesive bonds of the super glue
Old Jun 14, 2025 | 11:12 PM
gtrslngrchris
It says that because usually there is acetone in it which will definitely mess up the paint.
Old Jun 14, 2025 | 11:22 PM
RedC5's Avatar
RedC5
I used it today for my touch ups and many times before - dab on cloth right on my clear coat! No issues!
Old Jun 15, 2025 | 12:51 AM
Check with a good body shop - perhaps they have had some experience getting glue like that off.
Old Jun 15, 2025 | 12:03 PM
gtrslngrchris
That is great for your car and your paint. I would not be recommending it to others at a MINIMUM without being upfront about the risks. The fact is acetone is a solvent that will act on your clear coat and lacquer thinner will have acetone. In the OP's case the super glue will not be dissolved immediately so it will have to sit there and work and it isn't going to work only on the super glue.
Old Jun 15, 2025 | 02:57 PM
Thrash's Avatar
Thrash
Dawn Powerwash! Dab some on & let it sit a few times, then chip it away with a plastic razor blade.
Old Jun 15, 2025 | 04:02 PM
CFight's Avatar
CFight
From the manufacturer, Hand cream! lol.
https://www.loctiteproducts.com/idea...car-paint.html
Old Jun 16, 2025 | 11:14 AM
zone-7's Avatar
zone-7
Before doing anything drastic, try a product made to do this job.
For example.....
Starbond Super Glue Remover
Amazon has it
Amazon Amazon
Old Jun 16, 2025 | 04:39 PM
hyperv6's Avatar
hyperv6
I just used some 3m adhesive remover I found at Walmart. Not sure it will work but it removed what Goo Begone would not touch as well lighter fluid.
Old Jun 16, 2025 | 10:18 PM
Alley Oop's Avatar
Alley Oop
if unsure of the remover's effect on paint, try the remover on a hidden portion of your paint job.
Old Jun 16, 2025 | 10:22 PM
killain's Avatar
killain
Oldtimer
This will work, but you will need to use Q-tip and work slowly till your at a point where you might be able to use some touch-up in your color to blend it in ?
To Super Glue removal
