intermittent Turn signals
Old Jul 4, 2025 | 11:51 AM
coat1971's Avatar
coat1971
Default intermittent Turn signals
have the flasher switch here for my 2002 and about getting ready to try the replacement by going up under the knee bolster. Just as I'm getting ready to try I see threads on the hyperflash harness that most use to correct for using new LEDs in the rear lights. some have said that this pigtail harness is a fix for the intermittent turnsignal problem. Thoughts/experiences! Pigtail looks like an easier install if it would indeed fix my intermittent turnsignal problem! thanks in advance
NEWZQ LED Hyper Flash Fix/Signal Fix/LED Bypass Hyper Flash Harness C5HFH Replacement for 1997-2004 Chevy Corvette 2-DoorDorman 924-609 Hazard Warning Light Switch Compatible with Select Chevrolet Models
Old Jul 4, 2025 | 11:54 PM
I installed the product on the left on my 2000 and 2003 - worked perfectly to prevent the hyperflash problem.
Old Jul 5, 2025 | 08:06 AM
dood73's Avatar
dood73
I did the pigtail type on my 02Z when I switched to LED turn signals and tails. Easy install. Has worked perfectly for 12 years now.
Old Jul 5, 2025 | 08:38 AM
oktx's Avatar
oktx
I used the hyperflash harness to fix a bad flasher issue. Works great and very easy install.
Old Jul 5, 2025 | 09:16 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Not every intermittent turnsignal problem has identical symptoms or causes.
I would investigate further before throwing parts at the issue.
Old Jul 5, 2025 | 11:50 AM
coat1971's Avatar
coat1971
was your fix able to restore the turnsignals?
To intermittent Turn signals
