C5/C6 TPMS Relearn fix 2025 update
I'll keep this short. About 20 months ago, I had a new set of tires installed along with Schrader TPMS sensors. When I picked up the car, the shop told me they couldn't activate the TPMS sensors using the supplied magnet—they kept getting an error on their scanner. That was the extent of the explanation.
Since then, I've tried at least a dozen times to activate them myself, following threads from various forums and advice from ChatGPT. Interestingly, ChatGPT suggested I needed a TPMS scanner to activate the sensors. I was confused—did I need one?
Fast forward to Friday: I ordered an inexpensive TPMS-capable scanner from Amazon (see below). I followed the relearn procedure, and although the scanner said "Failed" after each step, something odd happened—the car responded.
First, it triggered the horn, then the DIC (Driver Information Center) prompted me to move to the right front tire. The horn honked again, even though the tool still showed "Failed." The DIC then instructed me to go to the right rear tire. Same thing—the tool said "Failed," but the horn honked, and I followed the prompts to the left rear tire. Another horn honk, another "Failed" from the tool.
But here's the kicker: despite all the "failures," all four tires are now showing up on the DIC and communicating correctly. No magnet was needed.
Thank,
Lee
Autel MaxiTPMS TS501 PRO TPMS Programming Tool, Same as TS508, 2025 TPMS Relearn Tool Newer of TS501 TS408S, Activate Relearn 99% Sensors, Program Autel MX-Sensors [315/433MHz], TPMS Reset/Diagnosis
Thank,
Lee
I had the new Schrader sensors installed in my car when they mounted and balanced the new tires/wheels.
They are programmable sensors, they do not activate by magnet.
They programmed mine, but I need to take my car back and get them synced to the car, car was not on hand when I picked the tires/wheels up.
That scan tool is EXPENSIVE!!!
It was yesterday. It was $186 on Friday, today $175 ish. My logic was that the TPMS sensor, which used older technology, required the OEM valves to be installed. How was I to know that the new TPMS was compatible with the '03 computer? Now I /We know.
Thx
Amazon.com: GM TPMS Relearn Tool Chevy TPMS Reset Tool for Chevrolet Cadillac GMC Buick Tire Pressure Monitoring System Sensor Reset Tool Activation for Chevrolet Cruze Silverado Traverse TPMS Tool EL-50448 : Automotive
My tire guy used a Schrader TPMS scan tool to program the sensors for my car, they came unprogrammed, entered the year, make and model to program them.
OER vs EZ Sell Sheet 052020.pdf
Schrader has integrated over 700 million direct-fit sensors on global vehicle platforms since launching TPMS on the first production vehicles in 1997 (Chevrolet® C5 Corvette and Plymouth Prowler platforms).
