Help! Gas Leak...
Old Aug 2, 2025 | 05:48 PM
Stephen7's Avatar
Stephen7
Default Help! Gas Leak...
Hello.
My 2002 Z06 has a gas leak somewhere on the main tank crossover or lines. it starts leaking as soon as i turn the key on and it pressurizes dripping in front of the drivers rear wheel. I assume its filling the bottom plate then running out at the lowest point. I don't have a lift and cant really get under it to see where or what i need to fix it. Is there any one in the Findlay Ohio area with a lift that could help me out.
Thanks Stephen
Old Aug 2, 2025 | 07:11 PM
glbeauchamp's Avatar
glbeauchamp
Alift probably won't help because all the hoses are on top of the tank. Had the same problem. A squirrel chewed through the return line. The only time the line leaked was when it was under pressure. You'll probably have to drop the tank to find it
