Sharp Light Innovations vs Vette Lights
https://sharplightinnovations.com/sh...aca-headlights
https://www.vette-lights.com/collect...t-dot-approved
@TheRadioFlyer I think you might be the guy to chime in on this
Appreciate any insight into this/breakdown.
Popular Reply
The story behind the ACA headlights is complicated but interesting:
Around 2002, the company ACA (I believe based in Canada) created the initial design of the headlights. They were originally designed with a D1S HID projector (low beam only) and used a halogen high beam. The headlights were manufactured in Taiwan. The problem was that in the initial design, someone forgot to check if the low and high beam were correctly aligned for each housing....they were not. IIRC, the spot-pattern high beams were pointed way too low and because it was a solid housing, there was no way to change this. The ACA company gave up selling them and the factory in Taiwan decided it could sell the remaining stock by converting the expensive D1S HID projector to a cheap H9 Halogen version.
Circa 2011, I figured out a way to modify these lights to use a Bi-Xenon H1 HID projector and re-aim it slightly to correctly align it with the halogen high beam. This was followed shortly by replacing the halogen bulb with an LED bulb which changed the spot pattern to a flood pattern. With this design, the misalignment of low/high beams was no longer an issue.I purchased remaining inventory of the old Halogen versions and converted them to Bi-Xenon projector systems. The product was so successful that the factory in Taiwan began producing the lights again to meet demand.
By 2020 (amid covid) LED projectors in this size class finally (and reliably) overtook HID projectors in overall performance and we phased out the HID variant for the LED version. The gen 2 projector appeared in 2021 providing improved output and an internal LED driver. By 2022, The factory in Taiwan began installing their own LED projectors with a silicone boot type of weather seal. These projectors are a further improvement from the Gen 2 version. This 3rd Generation version is sold by various vendors, but (as far as I know) I am the only vendor who supplies a Hi-4 harness (that keeps the low beams on with the high beams and is contained completely within the under hood fuse box), and a unique harness that allows correct headlight door raise/lower function without the need for a dangerous headlight resistor.
I introduced the Nova-Edition projector (as an upgrade option) in December 2024. This version out-classes everything before. Nova edition is by far the most powerful headlight system for the C5 AND does this without causing unwanted glare to oncoming traffic (in low beam mode). There is not likely to be much change of any further improvement in low or high beam performance.
I did not "invent" the ACA headlights, Over the past 15 years, I've been tinkering with them in various forms to make them much better.
Sharp Light makes several of his own products. I think he also distributes some products that are commonly available elsewhere, but they also have some products that they're the only ones making.
Now all that said, I have bought some from Vettelights. Zero complaints, just prefer Sharplight generally.
I then upgraded to George’s Bi-Xenon ACA HID kit with 4-on harness a few years ago and they have been working great with less wiring. Now I’m considering having him upgrade my current set to his Bi-xenon LED kit as I would like to remove the four HID ballasts I currently have mounted for both my HID lows and HID fogs as I need the real estate for mounting oil and trans cooler plumbing and other auxiliary components associated with my supercharger build.
As to each vendor, I think both are very good, however George and Sharp Light Innovations really led the way with his custom modifications and customer support.
https://sharplightinnovations.com/sh...t-modification
Upgrade the fog lights too and you won't have any ballasts taking up space:
https://sharplightinnovations.com/sh...-light-upgrade
