Tune up question
Old Nov 9, 2025 | 01:00 PM
Ltngdrvr's Avatar
Ltngdrvr
Deterioration of the plug wires, comes from heat cycling more than anything else, and on this particular car, with such low miles, hasn't had that much heat cycling to deteriorate the plug wires.
But, you know what? The OP can do as he wishes, it's his car, not anyone else's.
Old Nov 9, 2025 | 01:02 PM
Kingtal0n's Avatar
Kingtal0n
dont forget to also always carry a bit of bulb grease, diaelectric grease as well, insulate those wires and protect from seizure , and it goes on bulbs and such as you go replace for maintenance
Old Nov 9, 2025 | 03:22 PM
hyperv6's Avatar
hyperv6
Originally Posted by old stingray
Apples and oranges.
‘No plugs and wires.
This is a Corvette not a Chevette. Take care of the car.
Old Nov 9, 2025 | 03:26 PM
hyperv6's Avatar
hyperv6
Originally Posted by Fcar 98
I agree, not only do the wires deteriorate. The plugs after all those years do become a problem removing. They can
seize up. Not that they are bad, but in my case I plan on keeping this car and don’t want a bigger problem down the road.
Yes the plugs can stick in some cases with time and age. The wires will get brittle either heat. Even with low miles high temps from driving hard or driving in high temp regions.
I know done if you may have to pay someone to go this but if you go it yourself it is not expensive. No excuse not to do it.
