[Z06] NEW BEST TIME !!!
Old Feb 18, 2003 | 10:52 PM
LingenfelterC5's Avatar
LingenfelterC5
Default NEW BEST TIME !!!
I did a 12.12 @116 the other day at the track... I massively bogged launching at 3k RPM
Old Feb 18, 2003 | 11:52 PM
Z06_2002's Avatar
Z06_2002
Default Re: NEW BEST TIME !!! (LingenfelterC5)
Nice job!
:cheers:
Old Feb 18, 2003 | 11:57 PM
VetteLuv's Avatar
VetteLuv
12.12 with a bog sounds like you are on your way and real close to 11's.
Nice run! Hope the next does the trick! :chevy :flag :chevy :flag
Old Feb 19, 2003 | 12:40 AM
BLU-BY-U's Avatar
BLU-BY-U
bog? try a +5k launch :D
Old Feb 19, 2003 | 12:43 AM
SharkbyteLT4's Avatar
SharkbyteLT4
Default Re: NEW BEST TIME !!! (BLU-BY-U)
:withstupid:
Old Feb 19, 2003 | 10:46 AM
Ranger's Avatar
Ranger
Nice run!
If the car bogs at a particular launch rpm, suggest you raise it by 200-300 on the next pass and do so successively until you find the sweet spot. At the sweet spot rpm the tires will spin just a little and then hook hard and the rpm will immediately climb very fast. Usually this occurs between 3000 and 4200 on DRs. The exact rpm depends on the interrelationship among many variables. But to keep the variables manageable, changing one at a time, such as the launch rpm, brings consistency faster.
Doing this consistently requires getting the clutch out fast, certainly within the first 4'-10' of forward movement; not a side-step nor a pop...but a quick release.
I'd suggest avoiding launches above the low 4000s, north or there the wear-and-tear to the clutch and drive line entails substantially more risk of premature failure.
Ranger
Old Feb 19, 2003 | 01:16 PM
GaryZ06's Avatar
GaryZ06
Nice run ... :cheers:
Old Feb 19, 2003 | 01:57 PM
Scott-2002-Z06's Avatar
Scott-2002-Z06
Default Re: NEW BEST TIME !!! (GaryZ06)
Nice run indeed! :cheers:
Old Feb 19, 2003 | 02:19 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Looks good.
What was the 60' and the 660'?
To NEW BEST TIME !!!
