Need a part number.
Old Jan 28, 2026 | 03:01 PM
Tuffy94's Avatar
Tuffy94
8th Gear
Default Need a part number.
I unfortunately lost a part of my corvette. It is for the center cargo cover. The part I need to find clips into the cover to hold the cover down. Any help will be greatly appreciated. TIA
Old Jan 28, 2026 | 04:19 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Doesn't look like there is a part number. The whole cover was sold as an assembly. https://www.gmpartsdirect.com/v-1999...trim-rear-body
Old Jan 28, 2026 | 04:31 PM
redzg's Avatar
redzg
Not all, but the vast majority of parts can be identified via the C5 Parts Manual .pdf. I never seem to have the link handy, but a quick search will turn it up. The zip file is on the order of 125MB, so too big to just email.
Regardless, if the part you're looking for is #4 on this graphic, then the part number is 10290666. Long since discontinued, of course, but good used are available, and not all are ludicrously over priced:
https://corvetterecycling.com/c5-cor...PmoyZJDxEuGSqv
Old Jan 28, 2026 | 08:06 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Is this what you're looking for?
https://www.corvettestoreonline.com/...e-store-online
Old Jan 29, 2026 | 12:34 PM
Good luck - sounds like a solid lead above. Or try a used parts vendor like Vettenuts and see what they have. No idea what they would charge for the part.
Old Jan 29, 2026 | 10:40 PM
Tuffy94's Avatar
Tuffy94
8th Gear
[QUOTE=Johnny Hardcore;1609407384]Is this what you're looking for?
no what I’m looking for is the piece of metal that piece clips into.
Old Jan 30, 2026 | 08:26 AM
Johnny Hardcore
[QUOTE=Tuffy94;1609409975]
Can you share a picture of the piece from one of the other panels it isn't missing from?
Old Jan 30, 2026 | 01:48 PM
redzg's Avatar
redzg
Will take a photo when I get home, but unless I am very much mistaken the piece of metal it inserts into the edge of the big bin, #11 in the graphic above, no?
Old Jan 30, 2026 | 02:22 PM
Tuffy94's Avatar
Tuffy94
8th Gear
[QUOTE=Johnny Hardcore;1609410317]
It’s similar to this but for the center
That part fits here
That part fits here
Old Jan 30, 2026 | 07:49 PM
Johnny Hardcore
I've never come across that piece in my 20+ years of shopping C5 parts. As suggested by redzg it's likely comes attached to #11 above. I highly doubt you'll find it via a part number (different from #11) or as a small stand alone part from a vendor.
Follow Jack's lead and contact Vette Nuts to see if they can source it for you. One of the Corvette salvage specialists is likely your only choice.
Old Feb 1, 2026 | 01:58 PM
old stingray's Avatar
old stingray
or maybe find it at a Corvette show/ swap meet.
Old Feb 1, 2026 | 04:01 PM
redzg's Avatar
redzg
Still confused. The center cargo lid only has two latches, one on each side -- is the photo indicating the L/H is missing? That's wild. I pulled my cover yesterday but did not think to pull the carpet back sufficiently to see if it's a riveted mount plate. We still haven't hit 50f today, but might wander out just for the edification. If it is a riveted plate, should be reasonable simple to duplicate.
To Need a part number.
