Affordable ramps
Old Apr 3, 2026 | 10:04 AM
grinder11's Avatar
grinder11
Originally Posted by Ltngdrvr
Sure, go to home depot and buy a couple of 2x10x8 treated boards, a box of screws and make some.
This is exactly what I did, except plain wood, not treated. Work as good as any other, and cost is very cheap. ALSO-I used a masonry bit and my DeWalt hammer drill to drill a hole in the concrete, just in front of the properly placed ramps. Stick a 1/2" diameter, approximately 3" long carriage bolt (carriage bolts have a nice rounded head) in each hole, and the ramps wont scoot forward. I bought stainless steel bolts because they resist bending better. FWIW.....
Old Apr 3, 2026 | 10:09 AM
grinder11's Avatar
grinder11
Originally Posted by VETTEYOG
I have Rhino Ramps and just built approach ramps out of 2 x 6's. With the approach ramps I can drive the front right up on the ramps.
If you're building wood ramps, you do run the risk of running a bit off the ramps using 2×6s. Don't ask!!
Old Apr 3, 2026 | 10:10 AM
shovel52's Avatar
shovel52
I bit the bullet and bought the race ramps with the low angle approach ramps. I think it was one of the best purchases I ever made. I use them on my Grand Cherokee, my Colorado, the Corvette, and my girlfriend's Toyota. I use them more than I ever thought I would. No regrets at all. Ken
Old Apr 3, 2026 | 10:16 AM
shovel52's Avatar
shovel52
On another note, I bought mine a few years ago when I put in a new fuel pump and did some other work. I thought about the car rolling off of the ramps and did a little modification. Probable over-kill, but the word kill is involved. LOL
Simply made me feel better.
Old Apr 3, 2026 | 12:26 PM
RogerZ06's Avatar
RogerZ06
Just buy harbor freight low profile jack.
Old Apr 3, 2026 | 01:41 PM
AutoAvngr2020's Avatar
AutoAvngr2020
I have to agree. To be honest, get the proper tool for a proper job. Money well spent than spend over a Benjamin on some cheaply made house brand ramps that still have a questionable approach angle.
The approach angle is key on using for the application and Race Ramps have it. You have the money spend it as needed.
We all want to take care of our vehicles the best we can and safely. The return on investment for Race Ramps is high especially if a person has a fleet of several vehicles.
Old Apr 4, 2026 | 02:03 PM
Tommy Bahama Fan's Avatar
Tommy Bahama Fan
Not only this, what I like a whole lot about my two piece race ramps. They are light as heck. Easy to hang on a wall where ever you want. And do not make annoying (To me anyway) scraping noises when you slide them on the floor.
Old Apr 5, 2026 | 11:39 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Originally Posted by redvette1991
Are there any good ramps out there that don't cost $300 or more that a C5 will clear and raise it high enough to get under?
No. Even the 10" lift Race Ramps don't get the car high enough to easily do much under it.
If you're used to just rolling the creeper under your vehicle up on the ramps and rolling around to do whatever it ain't happening with a Corvette.
Old Apr 6, 2026 | 10:42 AM
hyperv6's Avatar
hyperv6
Race ramps are good but expensive. The plastic ramps are not questionable. They are solid and cheaper but heavier and not as easy to store.
The Wood is cheap but even heavier and harder to store.
Pick your poison. There is no right one for all. They all lift about the same and if you need more you need a Quick Jack or a lift.
Old Apr 10, 2026 | 08:59 AM
VETTEYOG's Avatar
VETTEYOG
2024 C5of the Year Finalist - Unmodified
Never had a problem in 5 years!!
Old Apr 10, 2026 | 12:16 PM
1999corvettels1's Avatar
1999corvettels1
That, and they are currently on sale for $97.99 for the Pittsburgh 3 ton low profile jack this weekend!
Normal price is $169.99.
I bought Rhino ramps in 2003 right after getting my 1999 Corvette, in 2018 bought that low profile jack and made jacking pucks.
Still use the rhino ramps but jack one side up, put ramp under wheel then do other side.
The rhino ramps are a tad too tall for C5 but work good for driving up onto without issues on the other vehicles.
https://www.harborfreight.com/3-ton-...ray-70482.html
Old Apr 10, 2026 | 12:23 PM
1999corvettels1
Also this low profile 3 ton long reach jack is on sale also, it lifts a little higher and instead of grey/silver you can get it in 4 choices of colors green blue orange black.
https://www.harborfreight.com/3-ton-...lue-56641.html
The sale ends Monday the 13th.
