Stoptech Brake Rotor Replacement
Old May 9, 2026 | 03:35 AM
tubegearhead's Avatar
tubegearhead
Default Stoptech Brake Rotor Replacement
Since Stoptech is no longer in business, are there alternative or compatible rotors for ST60 / ST40 calipers? Rotors are 355mm x 32mm.
Old May 9, 2026 | 10:43 AM
Lowend's Avatar
Lowend
Hmm - good question. I did a little hunting around and the info is spotty. I'll suggest you call Buybrakes.com and talk to John Butler, he was a Stoptech dealer and has a lot of general industry knowledge. I bet he has a solution for this.
Old May 9, 2026 | 11:56 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
Might try RacingBrake or Coleman.
Old May 9, 2026 | 07:22 PM
USAZR1's Avatar
USAZR1
Depending on offset, those rotors sound like a C6 Z06 spec.
edit: sorry, didn't realize those rotors were two-piece.
Old May 11, 2026 | 08:36 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
You can get replacement rotor rings from Girodisc.
Old May 11, 2026 | 08:39 AM
G Man's Avatar
G Man
Zeckhausen.com
Old May 12, 2026 | 05:26 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Originally Posted by G Man
Zeckhausen.com
Good call. I chat/message with David Z. often. He's a WEALTH of knowledge, and will bend over backwards to make things happen.
Old May 13, 2026 | 10:04 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
I know that BimmerWorld has helped one of my fellow racers match up rings for his Mustang as well.
Old May 20, 2026 | 03:30 PM
jjc508520's Avatar
jjc508520
Aha! Now I know why the slotted/cryo-treated rotors I use on my SUV are no longer listed on the Tire Rack site!
To Stoptech Brake Rotor Replacement
