Targa top leaking in front
Old May 23, 2026 | 03:19 PM
Wh0me's Avatar
Wh0me
Cruising
Default Targa top leaking in front
I had some work done on my targa top a few years ago and had the rubber replaced on both sides. I finally figured out why it keeps leaking.
After some investigation, the seals are leaking on either end where it screws in to the targa.
Found a video that said to put calking tape on the ends of the rails. Will try that tomorrow. Also said to use light adhesive, but wasn't sure if that was needed just keep things in place or if it prevented leaks as well.
Old May 29, 2026 | 11:13 PM
I have some Word files that relate to water and air leaks on the C5. If you would like a copy of the files, PM me an e-mail address and I will send them to you.
