[Z06] Do the '02s have a problem with a Blackwing?
Old Feb 26, 2003 | 11:44 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Default Do the '02s have a problem with a Blackwing?
I remember hearing that some people were have surging problems when they put a Blackwing on their '02 Z06. I was wondering if there was a definitive answer, or solution, regarding this claimed problem. Is it something that just varies with the particular car, which could be "tuned" out? Inquiring minds want to know. Thanks.
Old Feb 26, 2003 | 12:59 PM
TRR's Avatar
TRR
Default Re: Do the '02s have a problem with a Blackwing? (wamara)
I have not had that problem with mine :nonod:
TRR
Old Feb 26, 2003 | 01:04 PM
Ryan Bell's Avatar
Ryan Bell
Cruise-In III Veteran
Cruise-In IV Veteran
Mine threw a "lean" code once, but I cleared it and it's never come back. :blueangel:
Old Feb 26, 2003 | 01:06 PM
Scooby Snacks's Avatar
Scooby Snacks
Only thing I noticed after installing my blackwing and this was on the dyno BTW was that I gained around 10HP and TQ on the low end but lost about 13HP on the topend. Using the Predator I was able to regain what I lost on the topend and keep that extra on the lowend and a bit more. But I never noticed any surging.
here is a graph showing stockand blackwing.
graph after leaning it back out with the Predator.
run1 = stock
run4 = stock tune + blackwing
run12 = blackwing + tweaked predtune
[Modified by Scooby Snacks, 3:18 AM 2/27/2003]
Old Feb 26, 2003 | 07:50 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
Default Re: Do the '02s have a problem with a Blackwing? (Scooby Snacks)
No codes or surging, but WOT sure sounds meaner!!!! ;)
Old Feb 27, 2003 | 02:33 PM
Patriot24's Avatar
Patriot24
Default Re: Do the '02s have a problem with a Blackwing? (Airwolf)
No problems with mine as of yet!!! :jester :jester
Old Feb 28, 2003 | 02:13 AM
octaneman's Avatar
octaneman
No problem with mine, gained peak of almost 11 rwhp and about same on torque, after driving for 2500 miles, no codes, then threw on the real ram air..a vortech supercharger :lol:
Old Feb 28, 2003 | 11:04 AM
wamara's Avatar
wamara
Default Re: Do the '02s have a problem with a Blackwing? (octaneman)
Thanks everyone for your input.
Old Feb 28, 2003 | 05:43 PM
Go_Fast's Avatar
Go_Fast
No problems here ...just installed mine a couple of days ago.
Old Feb 28, 2003 | 05:58 PM
hebertjb's Avatar
hebertjb
I was wondering the same thing about my 03 Z06. Do less restrictive intakes usually result in running richer or leaner? :auto:
Old Mar 12, 2003 | 07:22 PM
JWC80's Avatar
JWC80
8th Gear
Not to sounds stupid but what is the predator, and what kind of tuning was involved. Looking at getting a blackwing for my 02 Z.
Old Mar 12, 2003 | 07:48 PM
Greg_E's Avatar
Greg_E
Default Re: Do the '02s have a problem with a Blackwing? (JWC80)
It is a hand held programming device that plugs into your obdII port. Your stock GM computer tuning program can be uploaded and stored in the device and the custom tuning program in the Predator is then downloaded to to the ECM. For more info read the posts in the scan and tune section posted by RWTD and others.
Old Mar 12, 2003 | 09:03 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Wayne -
I have not heard of anyone having trouble with a blackwing - very high quality air filtration unit by a reputable company.
Did you get your car? Ron was asking - Are you planning the VetteFest this weekend?
Best Regards -
mqqn
Old Mar 12, 2003 | 10:41 PM
DRDVETTE's Avatar
DRDVETTE
Default Re: Do the '02s have a problem with a Blackwing? (mqqn)
I had a problem with mine. I actually felt like I lost power. I don't still have the article, its been over a year ago, but an engineer from the company that made the blackwing said that once a certain volume of air was flowing that the computer on the 02 did not have a scale high enough to mix the correct ratio of fuel, so once the air volume went off the scale the injectors went to wide open producing a flooding type effect. There was a fix but there was reprograming involved costing a few hundred if I remember correctly. I ended up putting the stock filter back on.
To Do the '02s have a problem with a Blackwing?
