[Z06] Injector Failures
Old Mar 7, 2003 | 01:19 AM
Bimota Guy's Avatar
Bimota Guy
Default Injector Failures
Car started running rough and "Check Engine" light began flashing. Diagnosis was 3 bad fuel injectors. Is this a common failure?
TIA...
Old Mar 7, 2003 | 01:58 AM
Swimmer's Avatar
Swimmer
Default Re: Injector Failures (Bimota Guy)
I have never heard of that happening to anyone. I wonder what would cause "3" of them to go bad at once?
Old Mar 7, 2003 | 02:58 AM
johnC5's Avatar
johnC5
TIA...
Cut wire bundle?
Old Mar 8, 2003 | 01:46 PM
Bimota Guy's Avatar
Bimota Guy
Default Re: Injector Failures (johnC5)
Cut wire bundle?
No mention of anything like that from them.
Old Mar 9, 2003 | 08:32 PM
rickvette's Avatar
rickvette
Sorry to hear about your injector trouble. My friends Z06 on the way to the 2002 Corvettes at Carlisle did the same thing as what you have described. I checked each connection under the fuel rail covers and at each injector all were fine. I added in a 4 oz. bottle of Red Line S-1 Fuel Injector Cleaner and he drove off for about 5 miles. Guess what- no more check engine light, roughness or problems! I'm not saying this is a cure all but worth a try. What type fuel are you using and the mileage on your Z06- Do a fuel pressure test to see if the filter is partially clogged (bad fuel load(s)).
Old Mar 10, 2003 | 04:25 PM
Rebelskum's Avatar
Rebelskum
This happend to me, #7 injector quit working and was getting a bad misfire. Then, I couldn't start the car anymore.
Diagnosis after the third trip to the dealership; cut/frayed injector wire. Seems it was resting on the enginer block.
This happend approx. 6 months ago, no problems so far...
:cheers:
To Injector Failures
