[Z06] HUD shift light
Old Mar 7, 2003 | 12:34 PM
dlsZ06's Avatar
dlsZ06
Cruising
Default HUD shift light
New to this forum, still figuring out how it works. I have a 2002 yellow Z06. The up shift light never comes on in the HUD. The book says it shoud work but the dealer tells me it doesn't on the Z06. Is this true. Don't really care about using it, but would like it to work if it's suppose to. Thanks for any info, looks like a good place for vette owners
[Modified by dlsZ06, 5:43 PM 3/7/2003]
Old Mar 7, 2003 | 12:43 PM
Tracy's Avatar
Tracy
Default Re: HUD shift light (dlsZ06)
It should work. I think you may need to change the settings that determine what you see. [the "page" feature] Do you have the tach feature turned on? Many of us use only the MPH and don't have the tach activated.
Again, the shift light should work, but I don't know of anyone who acutally uses it. Are you revving high enough? :D
Old Mar 7, 2003 | 12:50 PM
dlsZ06's Avatar
dlsZ06
Cruising
Default Re: HUD shift light (Tracy)
I have changed the page, I usually run with the speed and and the tach page. I've got my RPM's up many times. Like I said I don't need it, but if it was intended to work I want it to. Already wasted a day trying to get it fixed.
Old Mar 7, 2003 | 12:56 PM
Tracy's Avatar
Tracy
That's a puzzle! But your dealer is wrong....it is supposed to work....ESPECIALLY on a Z06!
Anybody else have some suggestions?
Old Mar 7, 2003 | 01:27 PM
pdvale's Avatar
pdvale
The shift light does work on the Z06. I have the hud displayed with speed, tach and oil pressure and the light does come on, however the 1-2 shift there is not much notice as the engine is revving so quickly. 2-3 and 3-4 you can see it.
I don't know if you need the tach displayed to see it or not.
:yesnod: :yesnod: :yesnod:
Old Mar 7, 2003 | 04:46 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Mine comes on somewhere around 6000 to 6200 rpm.
Old Mar 7, 2003 | 04:55 PM
backtrail69's Avatar
backtrail69
St. Jude Contributor
i didnt even know they had those
Old Mar 7, 2003 | 05:27 PM
Z06_2002's Avatar
Z06_2002
Default Re: HUD shift light (backtrail69)
It is pretty small and at the top of the HUD, I prefer to turn the HUD off and look at the big ole' tach :)
:cheers:
Old Mar 7, 2003 | 06:42 PM
GTB/ZR-1's Avatar
GTB/ZR-1
Default Re: HUD shift light (Z06_2002)
:iagree: I'm w/ this guy...
George
Old Mar 7, 2003 | 07:19 PM
george mourgos's Avatar
george mourgos
1st Gear
There is a shift light on the HUD screen and it kicks in at 6250rpms for every gear. I have a 2003 Z06 and use the shift light all the time. Just rev a little higher and you will see it...
Old Mar 7, 2003 | 08:29 PM
dlsZ06's Avatar
dlsZ06
Cruising
Default Re: HUD shift light (george mourgos)
I've tried all ways to make it work. When I turn the key on it blinks, I think that usually means there's a problem, does anyone else's do that? Just want to have something to tell the shop. Don't know why they can't call the factory and ask them--oh well
To HUD shift light
