[Z06] Help me decide..... Vararam or Vortex Rammer?
Old Mar 12, 2003 | 07:47 AM
RMilla17's Avatar
RMilla17
Default Help me decide..... Vararam or Vortex Rammer?
Im leaning toward vararam but was curious to get some input from you guys. thanks :banghead:
Old Mar 12, 2003 | 08:22 AM
User 81424's Avatar
User 81424
Default Re: Help me decide..... Vararam or Vortex Rammer? (RMilla17)
They are both expensive and involved, and it seems the vararam comes with a very cheap filter. In a worst case senario the vararam seems safer against water ingestion. I have a Halltech and I really like the batwing, just installed one on a freinds car. Have you looked at the blackwing?
Old Mar 12, 2003 | 10:09 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Help me decide..... Vararam or Vortex Rammer? (CPT Z06)
:_dupe: :_dupe: :_dupe: :_dupe: :_dupe: :_dupe: :_dupe: :_dupe: :_dupe:
Old Mar 12, 2003 | 10:12 AM
Z06 Quin's Avatar
Z06 Quin
The Vararam costs twice as much, and to the contrary, it would be more susceptable to water ingestion vs the Vortex Rammer. I personally don't think it's worth the extra $200 for minimal if any gains over the Rammer
Old Mar 12, 2003 | 10:26 AM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
We sell both and the Blackwing.
We've had a ton of happy customers with greatly improved track times with the V/R. Results is what it's about.:)
The COLD AIR(VR being one of them) kits will out perform the non cold air kits.:) Their manufacturers will tell you that, and have, in print on-line.:eek::)
Here is a recent article on the V/R:
http://www.vararam.com/vr1b_article01.html
No pulling of the front bumper either.:)
RG
Old Mar 12, 2003 | 10:39 AM
User 81424's Avatar
User 81424
Default Re: Help me decide..... Vararam or Vortex Rammer? (racer44)
Oh, give him a break, this question is never, ever going to go away! :lolg:
Old Mar 12, 2003 | 10:40 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: Help me decide..... Vararam or Vortex Rammer? (Z06 Quin)
This is still something that nobody has actually tested. I never tried the Vortex, but I got good results with the VR. Most cars will turn better times with the VR. My car now traps higher and gets lower ETs at the same time. That shows a true gain. I am recording faster cylinder fill rates and higher MAF rates. Mix that with the proper amount of fuel and you will make more power.
Stock dyno:
Click image for a larger view
VR Dyno with lower temp TStat and some LS1Edit tweaks done by me:
There can always be exceptions to the rule so there is no guarantee that every single car will see the gains I got.
Old Mar 12, 2003 | 12:07 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Help me decide..... Vararam or Vortex Rammer? (rbartick)
You will see similar ET and MPH gains with the Vortex Rammer..... :yesnod: :yesnod: :cheers:
Old Mar 12, 2003 | 12:12 PM
C5North's Avatar
C5North
From: HOPE is the first step on the road to disappointment.
Blackwing. Good enough for DRM and LPE...good enough for me.
Old Mar 12, 2003 | 12:45 PM
RG in Dallas
Elite Member
Cruise-In I Veteran
The VR will beat the BW any day of the week on a similar equipped car. Cold air kits perform better. Whether you like the install or look or design or price is up to the individual.:)
RG
Old Mar 12, 2003 | 01:02 PM
User 81424's Avatar
User 81424
That's outstanding info rbartick, but is it the "ram" design or the very high flow filter?
Old Mar 12, 2003 | 01:05 PM
ragvette's Avatar
ragvette
You can't go wrong with either one you pick.
BTW. I've got the Vararam installed.
Old Mar 12, 2003 | 02:19 PM
RussBt's Avatar
RussBt
Dyno gains obviously do not take advantage of any "ram" characteristics. I do not know if the "ram" design is actually responsible for any of the 1/4 mile gains I've seen. I don't really bother with the whole "ram air" debate anymore since that is not a selling point for me. I've seen small gains in MAP with the VR, but I do not know if they are large enough to actually cause a power increase. Maybe not.
I just try to get a little more air into the motor and mix it with the proper amount of gas. I like the design of the VR since it just makes sense to me and it looks factory. Starting another ram air debate would be worthless.
[Modified by rbartick, 2:27 PM 3/12/2003]
Old Mar 12, 2003 | 07:00 PM
Tracy's Avatar
Tracy
Ross,
You are absolutely 100 percent right!!
Old Mar 13, 2003 | 01:30 AM
User 81424's Avatar
User 81424
Roger that! and I too like the VR design, had a friend with a MY Z06 with mod red, and painted his VR red, that was very nice looking the way it matched the beauty covers.
Old Mar 14, 2003 | 09:39 PM
sunvet's Avatar
sunvet
The other day I came across a guy in a new Z06. I asked him if he'd opened up his intake, he said no. I have a '00 vert with Vortex, and I was able to stay within 1/2 car length of him up to about 80. The Varam looks great and doesn't require cutting a hole in the radiator plenum, but both will get rid of the blahs when stepping on the gas pedal.
Old Mar 14, 2003 | 09:42 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Re: Help me decide..... Vararam or Vortex Rammer? (sunvet)
I chose Vortex.... :seeya
To Help me decide..... Vararam or Vortex Rammer?
Old Mar 14, 2003 | 10:17 PM
03 Z06's Avatar
03 Z06
For what it's worth - Rupert Bragg-Smith says it's bad to change them out. Says the stock has perfect flow for the Z06s.
Old Mar 14, 2003 | 10:20 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Help me decide..... Vararam or Vortex Rammer? (03 Z06)
Yeh, but the engine will make more power with a Vararam or Vortex Rammer... :p:
Old Mar 16, 2003 | 01:30 PM
IM4A2Z's Avatar
IM4A2Z
I went with the VORTEX and the POWER DUCT. Bought at RG's!
