[Z06] What part # for 2002 wheel paint?
Old Mar 22, 2003 | 06:10 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Default What part # for 2002 wheel paint?
Just had new tires mounted and when the wheel weight was removed it revealed an inch long scratch. Just wonder if anyone has had to touch up their wheels and if so, with what?
Old Mar 22, 2003 | 06:44 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: What part # for 2002 wheel paint? (VNAMVET)
GM PB9789. Its called light metalic gray. I believe it was factory issue from gm in 1995. basically an old stock color. I bought a touch up tube at wal-mart for $2.97 today. I brushed a curb and scratched the wheel. Matches perfect. But because it is painted on and not airbrushed or painted on with a gun. It looks a little like it was painted on with a brush. but from 3 feet away you cant even see the scratch. cheap fix in my book
Good luck :cheers:
Old Mar 23, 2003 | 08:56 AM
VNAMVET's Avatar
VNAMVET
Default Re: What part # for 2002 wheel paint? (golfman)
Thanks. I did a search and turned up that #, but there was some disagreement as to 2001 color and 2002 color. Thanks again! :yesnod:
Old Mar 23, 2003 | 02:48 PM
golfman's Avatar
golfman
St. Jude Donor '05
THat's the 02 and 03 color. I no that for sure not sure on 01.
good luck
Old Mar 24, 2003 | 01:55 PM
Aerohawk's Avatar
Aerohawk
Where can I get this stuff? Someone said WalMart, is it sold as GM brand or what? Anywhere else? I let the G/F drive the car for a week while I was out of town, should have known better. Can you say curb rash???
Old Mar 24, 2003 | 03:02 PM
golfman1's Avatar
golfman1
2nd Gear
Default Re: What part # for 2002 wheel paint? (Aerohawk)
Walmart has it not sure what brand it is but they have a book of paint code by car maker you can cross reference. the color is light grey metallic. Do that or call the dealer and they should have it available. I went to discount auto before walmart and it was in there book but they didnt stock it. The color cameon a 92-96 gm car. The color is now used on the 02 and 03 z06 wheels.
Old Mar 24, 2003 | 06:46 PM
55SUX's Avatar
55SUX
Default Re: What part # for 2002 wheel paint? (golfman1)
9789 won't match 02-03 wheels. It's too dark. Should match 01 though.
[Modified by 55SUX, 5:48 PM 3/24/2003]
Old Mar 25, 2003 | 10:17 AM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: What part # for 2002 wheel paint? (55SUX)
Sorry but i totally disagree with that statement. I have used 9789 and it matches perfect cant even see the scratch anymore. it wont match 01 wheel paint. I think you have it backwards.
Old Mar 25, 2003 | 12:06 PM
Tom T.'s Avatar
Tom T.
Fellas, anyone know the correct paint code for the 2001 wheels. I've got a bit of curb rash I need to clean up.
Thanks!
TT :cheers:
Old Mar 25, 2003 | 01:20 PM
55SUX's Avatar
55SUX
That's strange. That's exactly opposite of my experience. Are you sure you don't have a 2002 with 2001 wheels? Some 2002's had 2001 wheels when Speedline couldn't meet the wheel demand. The 2001 wheels were definitely darker. Who is the manufacturer of the paint from Wal-Mart? I'll go check it out and compare it to the other 2 sources I have of 9789 (Paint Scratch and Plastikote).
BTW, I airbrushed mine and clearcoated it and did get a perfect repair that you can't tell was repaired. No exageration. I had to blend silver with the 9789 to get a perfect match.
To What part # for 2002 wheel paint?
