[Z06] help on vararam
Old Mar 22, 2003 | 10:39 PM
rellok's Avatar
rellok
Cruising
Default help on vararam
Just installed a vararam and have a hose on drivers side of car that has no hole to go back into, does anyone know what to do with the hose?
Old Mar 22, 2003 | 11:04 PM
Power Shifter's Avatar
Power Shifter
Default Re: help on vararam (rellok)
My VaraRam has a fitting to plug the air pump hose into the air box. Yours dosen't? (it probably does) look on the drivers side top of the box, the fitting should be obvious but if it's not there, give vararam a call but look again first. This ain't a halltech with no fitting. Ric
[Modified by Power Shifter, 11:12 PM 3/22/2003]
Old Apr 3, 2003 | 11:33 AM
LTs LT1's Avatar
LTs LT1
Default Re: help on vararam (Power Shifter)
Mike, try checking with John from Team ZR1, he is pretty good at those things. He fixed my LT1 up real nice!
Old Apr 3, 2003 | 11:52 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
You can either get a new airbox cover from Vararam that allows you to connect the smog pump line like this:
Click image for a larger view :)
Or you can just get a push-on breather filter from Pep Boys and stick it in the end of the smog-pump hose. FWIW, I would prefer to leave the smog line off the airbox cover. Less chance of a pressure leak.
To help on vararam
