[Z06] Pup Cat Removal on 2001
Old Apr 13, 2003 | 12:01 AM
01c5z06's Avatar
01c5z06
Default Pup Cat Removal on 2001
Has anybody gutted or removed the pre cats on a 2001 Z06??? Did it appreciably change the exhaust note or up performance??
thanks
Old Apr 13, 2003 | 11:38 AM
JWD01's Avatar
JWD01
Default Re: Pup Cat Removal on 2001 (01c5z06)
Do a search in the C5 tech section. Mike Mercury posted the complete procedure with pictures. I gutted mine and it took about 1 1/2 hours. I have a lift so add some time if you have to lay on your back to remove and install your system. When you see the pre-cats you will understand why they cost 5HP. Good luck :cheers:
Old Apr 14, 2003 | 12:03 PM
95jersey's Avatar
95jersey
I did not gut them, but replaced the entire H pipe with the 4 cats, with a high flow unit from Random. What a difference in sound and power! The stock set up really sucks. I would go with a new unit...your looking at around $400, but it comes with an X pipe as well, and you'll still pass emissions. They flow much better than the stock with only a single cat and sound great. There's only one problem...when burning them in it will smell like rotten eggs for a while, this goes away after a months use.
Old Apr 14, 2003 | 05:53 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Default Re: Pup Cat Removal on 2001 (95jersey)
Where did you get the Rando unit from? I'm really interested in doing something like this to mine. I was thinking about the Bassani dual x-pipe setup and totally eliminating the cats, but I might try this setup instead. We don't have emissions here, but I'd like to look at all the options.
Old Apr 14, 2003 | 06:03 PM
95jersey's Avatar
95jersey
Default Re: Pup Cat Removal on 2001 (EvanZ06)
Call....
Skip Norris
More Performance, Inc. http://www.moreperformanceinc.com
704-393-8241
Actually now that I look back at the info...the price was in the $600's.
You can look at the unit here... http://www.randomtechnology.com/
You note the C5 add in the upper right hand corner. I think the Bassini pipes are just as expensive. These are definately not as loud as strait pipes. The fit and finish were top notch.
Old Apr 15, 2003 | 09:04 PM
Anthony Singer's Avatar
Anthony Singer
I have a 2000 with 2001 Z06 exhaust and I have removed the cats. It sounds great to me however there is a resonance at about 2300 rpm.
Ps I am 65 yrs old and love the sound.
Old Apr 16, 2003 | 01:54 PM
dbvettez06's Avatar
dbvettez06
I put on TPIS headers, which also replaced the pup cats....The weight savings alone was 27 lbs! The sound is more mellow, without being too loud...Good choice in my opinion :cheers:
Old Apr 16, 2003 | 02:25 PM
GaryZ06's Avatar
GaryZ06
I had mine cut out and had a straight pipe welded in....Yes the sound got throatier.
[Modified by GaryZ06, 2:26 PM 4/16/2003]
To Pup Cat Removal on 2001
