[Z06] Shifter Brand
Old May 2, 2003 | 12:11 PM
Bman's Avatar
Bman
St. Jude Donor '05
Default Shifter Brand
The first mod I want to get for my new Z is a shifter.
I think I have narrowed it down to the "Breathless Performance Products" or the "The B & M "Ripper" shifter". I am leaning towards the BPP product because it looks to be far more adjustable.
Any opinions? or maybe a better product that Im missing??
Old May 2, 2003 | 12:18 PM
KMeloney's Avatar
KMeloney
Default Re: Shifter Brand (Bman)
You're probably missing the Mallett shifter. Way too expensive for some -- but, the cost is relative to just how much you want to enjoy driving your car. :)
(The Ripper is too darn stiff to be fun. I've heard similar stiffness issues with the BPP...)
Good luck!
-Kirk
Old May 2, 2003 | 01:27 PM
ledfoot's Avatar
ledfoot
Default Re: Shifter Brand (KMeloney)
I just put my old Ripper in my Z...I LOVE IT!!!:D
I would caution that if you're not into racing, don't buy it but Man, I gotta tell ya, when you're going down a drag strip, it's your best friend
i have not yet tried it on a race course but I'm very pleased with mine. The stock shifter is just too soft for my taste.
David In Indy
2003 Red/blk Z06
Old May 2, 2003 | 09:35 PM
Toms03Z's Avatar
Toms03Z
Another vote here for the Mallett shifter. Pricey yes, but you'll forget about the cost after you try it for the first time. :yesnod:
Old May 5, 2003 | 09:58 AM
Bman's Avatar
Bman
St. Jude Donor '05
Default Re: Shifter Brand (Toms03Z)
Does anyone have any comparisons between the Mallett and the Ripper or the BPP, As far as stiffness and overall feel? Thanks in advance..
Old May 5, 2003 | 10:24 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
You're missing the stock shifter mod, see the following post: http://forums.corvetteforum.com/zerothread?id=553047
Here's the link to the actual instructions: http://benelliwang.badassride.com/Shifter/index.html
I did version 2, but you could there are two other version as well.
All the benefits of an aftermarket shifter (shorter throw, firmer feel), without the drawbacks (noise, too stiff, cost). Total cost to me was $70, but that's because I bought another stock shifter to modify, otherwise total cost was $20 for a shift ****. I could have done it using my own if I'd known how easy it really is. Took me about 2 hours from start to finish.
Old May 5, 2003 | 10:39 AM
Bman's Avatar
Bman
St. Jude Donor '05
Default Re: Shifter Brand (EvanZ06)
Very coool I will check it out. :cheers:
But I thought that the shaft with the ball being longer than stock would result in a shorter shift throw??
[Modified by Bman, 10:40 AM 5/5/2003]
Old May 5, 2003 | 10:55 AM
rutiger's Avatar
rutiger
i have the b&m and have never had the chance to feel the others. i am very happy with my b&m though. i have one in my 94' as well.
the b&m suits my driving style perfectly. it's not too stiff to me.
i would love to try the others, but there's no way i can justify the price of the mallett without using it. i find it hard to believe that it can feel that much better.
as for the breathless, i almost ordered it. but then i felt that the less stuff i had to tweak and mess with the better. but i think the biggest reason i went with b&m is just my past experience with them.
Old May 5, 2003 | 11:02 AM
EvanZR1's Avatar
EvanZR1
Shift throw can also be shortened by shortening top part of the shaft. What you are talking about is actually moving the pivot point higher. The problem with doing this is that the stock noise isolator may no longer fit. Anyway, shortening the stock shifter works great. The throws are much shorter and much much more precise. I really can't imagine any improvement over this. :D
Old May 5, 2003 | 12:59 PM
Bman's Avatar
Bman
St. Jude Donor '05
Look at the shaft/ball size difference between the BBP and the Ripper, the ripper looks longer so I figured it would have a shorter throw than the BBP.
Old May 5, 2003 | 01:01 PM
Bman's Avatar
Bman
St. Jude Donor '05
If you modified the RIPPER to have a shorter top shaft it looks like you would have an amazingly short throw!! :D
Old May 5, 2003 | 02:08 PM
FAST's Avatar
FAST
I was going to install the BPP shifter,glad I didn't two people w/ Z's showed me that they vibrate like crazy. A couple others have other brands and it seems they are always missing shifts on the drag strip. I stayed with the stock unit never missed a shift on the track and no virbration. :steering:
Old May 5, 2003 | 05:37 PM
OhNiner's Avatar
OhNiner
Default Re: Shifter Brand (FAST)
I sticking with the stock for now, too many comments about other shifters. It seems that if you car is a strip car then go aftermarket. If a street/strip maybe, if street only stock is the best. That is just the impression I have from what I have read.
Old May 5, 2003 | 10:26 PM
ivox's Avatar
ivox
Installed my BPP this weekend.
Outstanding!
I recommend it highly.
The myriad of positions you can adjust to makes it a no-brainer.
Cheers...
~M
Old May 6, 2003 | 04:34 AM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Had the Ripper in my C4 and just installed one in my FRC. All I can say is FUN, FUN, FUN! :D
Old May 6, 2003 | 12:41 PM
CraigersZ06's Avatar
CraigersZ06
Hasn't anyone mentioned or considered the Hurst... I love mine and it's very accurate and a huge upgrade over stock.
:yesnod:
Old May 6, 2003 | 01:37 PM
Bman's Avatar
Bman
St. Jude Donor '05
Default Re: Shifter Brand (CraigersZ06)
:yesnod:
Does the Hurst have replaceable hard and soft springs too?
To Shifter Brand
Old May 6, 2003 | 02:59 PM
CraigersZ06
Ya - - You can go with mild, mid, or stifffff springs. I like the mid stiffness. CHeck out the Hurst web site - I got the billit shifter and LOVE it. I have a very built Z28 with a B&M ripper but I like the Hurst better on the Z06;
but that's kind of apple's & orange's comparison, I guess.. :steering:
[Modified by CraigersZ06, 12:00 PM 5/6/2003]
Old May 6, 2003 | 03:02 PM
ivox's Avatar
ivox
I went with the "mid" springs in the BPP and will prolly swap them out to the "soft" springs.
Can't imagine what the "hard" ones are like...yeesh.
~m
Old May 6, 2003 | 03:20 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
:yesnod:
I just think that most people are tired of these posts and are not posting anymore. If you do a search, there are lots of polls on which aftermarket shifter is used and Hurst is the overwhelming favorite. I am not saying that it is the best, I am just saying according to the polls most people are using it. :thumbs: :cheers:
