[Z06] Active Handling ?
Old May 12, 2003 | 07:42 AM
Rob's 73's Avatar
Rob's 73
Default Active Handling ?
Let me first preface this with saying that I don't have a lot of seat time with my Z. I am used to my 73. Anyway, yesterday while out for a cruise. I got on it a little leaving a red light. When I shifted hard into second the tires started chirping and then all of sudden the car slowed down for a second. It felt like it pulled me a little to the left. Scared the h@ll out of me so I let off the gas at the same time. When the tires were chirping the car did slide to the left a little but I wasn't expecting the sudden slow down.
Is this normal?
Old May 12, 2003 | 08:09 AM
woosch's Avatar
woosch
Default Re: Active Handling ? (Rob's 73)
You have just experienced traction control, the computer sensed that the tires where spinning faster than the car was moving ahead and momentarily ignored your right foot input.
If you don't want this to happen you can either shut off traction control and active handling by pushing the button on the console or you can push and hold the button for about 5 seconds and it will show comp mode on the D.I.C.
This disengages traction control but leaves active handling on.
Have fun.
Old May 12, 2003 | 08:16 AM
Rob's 73's Avatar
Rob's 73
Default Re: Active Handling ? (woosch)
So you are saying traction control actually shuts down the gas? I assumed it applied slight brake pressure to prevent the wheel from spinnning. For a spit second I thought I blew the car up. So much to learn
Old May 12, 2003 | 08:34 AM
jackmott's Avatar
jackmott
yep, it shuts down the gas. The throttle on the new vettes is electronic. There is no 'throttle cable'
so the computer is free to cut power.
it scares me too when I forget to turn it off. makes me think the engine exploded
[Modified by jackmott, 3:40 PM 5/12/2003]
Old May 12, 2003 | 09:21 AM
woosch's Avatar
woosch
Default Re: Active Handling ? (jackmott)
:iagree:
Old May 16, 2003 | 03:54 PM
FAST's Avatar
FAST
To avoid this hold button down on console 5 sec to put in competition mode.
IE: traction control off
active handling on
Will reset when engine is shut off or hit the button again, all info will come up on the DIC
Have fun :steering:
Old May 16, 2003 | 04:07 PM
prospero63's Avatar
prospero63
As mentioned, it is the traction control. Same thing happened to me, though it tends to happen when I shift to 3rd gear. It took me a while before I noticed that the DIC actually says "Traction Control Enabled" or something like that when it happens. Like many, the first few times I thought I had broke something... :D
Old May 16, 2003 | 05:14 PM
Highroller's Avatar
Highroller
Default Re: Active Handling ? (prospero63)
Had it happen on wet pavement, to bad there isn't a setting to at least disable TC until you turn it on, I like active handing.
To Active Handling ?
