[Z06] Help! Wont start! (off topic...sort of)
Old May 14, 2003 | 08:58 AM
MongoosC5's Avatar
MongoosC5
Default Help! Wont start! (off topic...sort of)
Mdad just brought home his new toy, a white 2000 TransAm Firehawk (he said he loved the vettes but they were a lot harder to get in and out of). Fully optioned, 7500 miles, auto with 3.23 perf. diff. The guy we bought it from has had it stored in his garage without starting it since early December! At first, it took a couple of tries to start but ran and drove Perfect. We've started and drove it about 3 or 4 times for 70 miles so far, but now it wont start. It turns over just fine, but never starts. What gives?? :confused: :confused: :confused:
I know its not a C5/Z06, but it is an LS1 and I was wondering if anyone might know what could go bad/wrong with not starting it for so long, and if anyone else has experienced this.
ANY help is Most appreciated!! :smash:
Thanks!
Mongoos
[Modified by MongoosC5, 8:16 AM 5/14/2003]
Old May 14, 2003 | 02:18 PM
BlackZ06's Avatar
BlackZ06
Default Re: Help! Wont start! (MongoosC5)
Could be any number of things. You'll probably want to see if there are any DTCs set.
I don't know how to get the DTC's from the PCM on a TransAm .... maybe you should post at:
http://www.ws6zxr.com/
See if anyome there can help you.
Good luck,
Steve
Old May 14, 2003 | 08:40 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
1) Hook a fuel pressure gauge to the pressure test port and check for key-on pressure.
2) Check the fuel pressure while cranking.
3) Pull a plug wire and check for spark while cranking.
To Help! Wont start! (off topic...sort of)
