[Z06] flat tire options
Old May 14, 2003 | 11:39 AM
whip383's Avatar
whip383
Default flat tire options
I just bought some z06 wheels for my '98. I will still try to use my sensors but am going with a non run flat tire. Does anybody have the part number for the kit that comes with the z06's or any other alternatives? Also, i need tires, any suggestions.
Thanks,
Chan
Old May 14, 2003 | 11:54 AM
texasredc8's Avatar
texasredc8
Default Re: flat tire options (whip383)
The sensors should mount just fine.
The inflator kit for the Z06 is overpriced. You can go to WallyWorld and get a small compressor, tire goop, valve tool, spare valve and even a seal kit for less than $50 out the door. I think the GM kit is $450+ with the tire goop alone being $50 to replace. You might want to consider not using the tire goop, as it will probably clog your tire sensor. SafetySeal.com has the best kits in the business at around $40, and will probably work to get you to the tire store if you can find the puncture.
Old May 14, 2003 | 11:55 AM
Mover's Avatar
Mover
I agree with Texas. Those kits are everywhere, and cheaper.
Old May 14, 2003 | 02:51 PM
whip383's Avatar
whip383
Default Re: flat tire options (BLKZO6)
ill check their website, thanks guys.
chan
Old May 14, 2003 | 04:19 PM
mgaskins's Avatar
mgaskins
buy Kumho for tires. Great value and performance...that's what I'm buying in a couple months.
Old May 14, 2003 | 05:52 PM
kraff's Avatar
kraff
Also, don't forget that any tire goop will ruin your tire sensors. :yesnod:
Old May 14, 2003 | 06:49 PM
whip383's Avatar
whip383
Default Re: flat tire options (kraff)
if i dont use the sensors, will my computer keep giving me warnings?
chan
Old May 14, 2003 | 07:30 PM
shaky's Avatar
shaky
I'm not really up on tire repair but have read on the forum that an alternate to the goop is a tire plug kit.
Old May 14, 2003 | 07:55 PM
texasredc8's Avatar
texasredc8
chan
Yes you'll get the warnings. The TPS can be turned off with a TECH2.
My suggestion is use the sensors and buy a plug kit. I would only use the tire goop as a last resort to towing.
A nail in the tire causes a slow leak which you can usually air up and get to a tire store. Large punctures that leak quickly can usually be repaired with the plug kit until you can get to a tire store. A blowout won't matter, because nothing will get you going except a tow.
Old May 15, 2003 | 02:22 AM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
Default Re: flat tire options (TexasRedZ06)
:iagree:
I know that for a fact! :cry
Old May 15, 2003 | 11:47 AM
whip383's Avatar
whip383
Default Re: flat tire options (w8d4it)
u guys are right?? ill keep the sensors in.
chan
To flat tire options
