[Z06] Are all Z06 the same?
Old May 14, 2003 | 08:25 PM
fhernand's Avatar
fhernand
Default Are all Z06 the same?
What I’m asking are all Z06 engine build the same? Are some engine peppier then other engines? If not how can I tell if I’m getting a live Z06 or a dud?
Frank
Old May 14, 2003 | 09:01 PM
Shylor's Avatar
Shylor
Default Re: Are all Z06 the same? (fhernand)
Not quit sure what you mean by "build the same". They are not the same engine as the coupe or vert. The 2001 Z06 has 385hp and the 2002/2003 has 405hp. The Z06 engine IS faster than the coupe and vert's. Didn't know there was any Z06 engine built that was a "dud".
Old May 14, 2003 | 09:30 PM
CJS's Avatar
CJS
If you look at dyno #'s from a lot of Z06's, you will see that they are about 355 rwhp. bone stock, but this is the average. You will see + or - 10rwhp, so the range is 345 to 365 rwhp, bone stock.
This range is because of cam timing differences, compression differences etc. That is why one particular car is faster that another.
Old May 14, 2003 | 10:29 PM
fhernand's Avatar
fhernand
Default Re: Are all Z06 the same? (CJS)
Thanks that's explains it! How can I dyno my corvette?
Frank
Old May 15, 2003 | 05:12 AM
WWK888's Avatar
WWK888
Take it to a shop that has a dyno...
Old May 16, 2003 | 12:30 PM
ZO6Les's Avatar
ZO6Les
First off there is VERY lttle variance motor to motor, I see you have a 99 FRC (not a Z06 - not that it matters) so make sure you are comparing to other FRC's, not a 2001 and up Z06. The variance you see in dyno runs is more to do with different dyno's and/or different days. A dyno is a relative measure of power, not an absolute.
So, look up a Chassis Dyno shop in your area, hook up with your local Vette club, and enjoy the car. And don't forget to wave!
Just my .02
Les
To Are all Z06 the same?
