[Z06] ? for cleartastic users
Old May 28, 2003 | 11:39 PM
jgmachine's Avatar
jgmachine
Default ? for cleartastic users
I order cleartastic for my car, not a bad product, but the rears do not go all the way to the bottom on my set. Is this normal? If it is, I am not happy because this is where most stone chips seem to be? anyone???
Old May 29, 2003 | 07:08 AM
Cleartastic's Avatar
Cleartastic
Premium Supporting Vendor
St. Jude Donor '03-'04-'05, '15-'16-'17
Default Re: ? for cleartastic users (jgmachine)
Give me a call today and I'll go over your question with you. :thumbs:
Old May 30, 2003 | 04:17 PM
TNT C5's Avatar
TNT C5
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: ? for cleartastic users (Cleartastic)
Ed will help you. I think the product is great. Installation is the answer to your problem and Ed will give you good advice. By the third time I put mine on I had it down. Took me less than 15 minutes and they were on perfect. Personally, I like to soak them in hot water with a small amount of Dawn in it after I remove them and then soak them in very hot water before I re-install. I have found using a mixture of 1/2 Z6 and 1/2 distilled water sprayed on the body makes installation a breeze.
To ? for cleartastic users
